Newer makeinfo tools cannot build the existing texinfo in gcc so
disable building it. This will not be fixed on the gcc branch.
Updates #3027.
The change lets the LM32 target build on Windows which has temporary
install paths greater than the Win32 API max size. The buildroot path
compression is still needed as the GNU assembler does not like paths
that exceed the max Windows limit.
Closes #2992.
The RSB documentation is now in ReST format and part of the RTEMS
Documentation project. See https://docs.rtems.org/.
Remove support for the GPL based asciidoc tool and remove the
asciidoc package from the RSB.
Add the Python Markdown package and update the reporter to use
Markdown for HTML generation. The resuling HTML report is a single
self contained file.
Closes #3047.
The released sources use the local file name so always force it when
the RSB is released.
Closes #3064.
Archlinux provides both, libguile v2.0 and v2.2. GDB states in
configuration its compatibility with both versions of libguile which is
false. The SCM_port interface of libguile was removed in v2.2 and
therefore breaks GDB as a user.
RTEMS does not use libguile and therefore it can be compiled without
support.
https://sourceware.org/bugzilla/show_bug.cgi?id=21104
Close #3054.
Enable traceability from the error message to the script location. This
eases debugging.
See also:
https://gcc.gnu.org/bugzilla/show_bug.cgi?id=69959
Always use the GCC provided zlib to make the compiler as independent of
the host system as possible.
Close #2947.
A release can specify a custom releaase URL path.
Closes #2952.
Gentoo stores most of the basic stuff in /bin and not /usr/bin. Default
values do not work for Gentoo. Add 'gentoo' as a new variation.
Signed-off-by: Ralf Ramsauer <ralf.ramsauer@oth-regensburg.de>
Select MinGW compilers for Windows builds on Windows.
Use the system readline rather than GDB's which does not
handle cmd.exe correctly.
The support is added at the top level and so not lost when we
move to a new version of RTEMS.
The change also moves all 3rd party packages to use a common
rtems-package.bset build set file.
All packages except Microwindows itself build cleanly.
Override the automatic file name of a downloaded file and use the file
name provided by the option. This is useful if the URL has no meanful
file that can be automatically extracted from the URL.
Directives in if statements end at the end of an if. The cannot
change or split across directive boundaries.
Add more trace detail to config.py.
Updates #2661.
Updates #2655.
Updates #2655.
Updates #2655.
Add support for pkgconfig checks to fail when just downloading the
source so it is actually downloaded on hosts that may have a package
installed.
Updates #2657.
Updates #2656.
The building of 3rd party packages for an RTEMS BSP requires a valid
BSP so the standard method to download the source for releasing does
not work. This change adds support to allow this. The RTEMS BSP support
will not generate an error is no BSP or tools are provided or found.
The change addis logic operators to the %if statement so you can '||'
to 'or' and '&&' to 'and' logic expressions.
A new %log directive has been added to clean up the messages.
A new %{!define ...} has been added to aid checking within logic
expressions.
All command line --with/--without now appear as macros.
Add version.version to get just the RTEMS major and minor version.
Some pkg-config issues have been resolved.
Closes #2655.
Some sites block the standard python user agent. Change to Wget
as it seems to make the tested sites behave.
Limit the size of long URLs when logging to the user.
Closes #2656.
Closes #2645.
If the package references macros yet to be defined an error is
generated. Let the macro expands happen when the package name is
actually used.
Closes #2645.
Ignore RSB generated files to keep the git dirty status clean.
Closes #2647.
Closes #2748.
Update #2526.
Provide without_release_url support in the configuration file so
the release tarball download of the kernel and tools uses the
release's top level directory and not the sources directory.
Closes #2481.
This reflects changes in the way the --with/--without options are handled.
Updates #2526.
Updates #2636.
The default without the option is to prepend the release URL to the URL
list to download from the RTEMS FTP site first if the RSB is released. This
option can force the RTEMS FTP to be tried first when not a release,
or you can supply a different URL to download from or you can request
no RTEMS URL is tried first. Eg:
--with-release-url
--with-release-url=file://opt/local/cache
--without-release-url
Move the RTEMS release URL to the default.mc file. Change the URL
to the RTEMS FTP server and do not use the https method of access.
The option's with_arg call was cleaned up to make sense.
Remove the log's raw output of an extra space.
Some download error message formating was cleaned up.
Closes #2636.
Updates #2619.
Updates #2619.
Updates #2619.
Detect a suitable Python version on Windows.
Update #2619.
Fix Windows support to allow MSYS2 Python to be used.
Updates #2619.
Add support so 4.9 builds on a recent FreeBSD using clang.
The query flags such as '?h=4.11' to select a branch cannot appear
in the file name on Windows. This patch removes the query part from
the file name.
Update #2616.
With a recent (Feb 2016) pytnon on MSYS2 the clear fails so delete
the variable.
Update #2613.
