Fix Windows support to allow MSYS2 Python to be used.
Updates #2619.
The query flags such as '?h=4.11' to select a branch cannot appear
in the file name on Windows. This patch removes the query part from
the file name.
Update #2616.
With a recent (Feb 2016) pytnon on MSYS2 the clear fails so delete
the variable.
Update #2613.
Windows cmd.exe does not support a single quote for options. Change to
a double quote.
Closes #2615.
Prepend 'sh' to the command so the autoreconf runs in a shell.
Is the first item in the path is a reference to MSYS2 remove it.
Closes #2613.
closes #2547.
Download source from ftp.rtems.org before the package's URL if
a release.
If a user adds a URL via the command line that is used then the
RTEMS release path then the package's URL.
A user can add --url=file://path/../morepath to have the RSB use
a local cache of source on their hard disk. This is useful if you
need to wipe the RSB and start again. Save away the 'sources' and
'patches' directories to a common directory and provide it with via
the --url option using the 'file://' prefix.
Closes #2482.
VERSION is an INI format file with 2 sections:
1. version
The version of the release. It contains:
release = version-string
2. hashes
A list of hashes for packages that are formed when creating a release.
A hash entry is:
file-name = hash-type checksum
The approach means we do not need to hold hash values in configuration files
which need to be updated when a release is made. The release scripts can
generate the hashes when creating the release.
Add a --without-error-reports flags to reduce the noise on --with-downloading.
Add support to release the RSB by adding the VERSION file. The file
is a single line with the version.
Fix the reports to include the version. Update the INI file
support to include the details of the build.
Show the GIT or released version when the command starts.
Closes #2480.
NetSNMP breaks building with extra jobs on fast hardware.
The change fixes installing for RTEMS 3rd Party packages where the
RSB considered them Canadian Cross Compiling (Cxc). Fixing the
Cxc issue broke real Cxc builds. The change corrects the issue of
macros being changed in the Cxc and the prep data not being udpated.
The configuration is loaded again after the updated macros. The
macros are also copied and restored to ensure a clean stable base.
The change also introduces --rtems-tools and --rtems-bsp to align
the command line with the waf configure process or RTEMS application.
This reverts commit 83d97daa070d67d177b90796ed22e4044ec9012c.
It contains a GPL license.
Check is the VDE development package is installed and if it is
enabled support.
Switch the default report to text format.
Fix the report to support the set builder.
The RTEMS servers are causing an exception when downloading patches. The solution is
provided in PEP-0476 (https://www.python.org/dev/peps/pep-0476/#opting-out).
This patch changes 'patch1' to 'patch0001' so sorting of the macro
keys in the patch macro map returns the order the patches are declared.
The helps mamage patch sets that need a specific order.
The --with/--without that does not have an extra option was
consuming an extra option on the command line.
Update the RTEMS tools and newlib-git to merge after the fetch.
The path handling has been cleaned up and support for file names
longer than 256 characters.
support.
You can now test downloading by using --dry-run and --with-download.
Print the redirect if one is taken.
This change uses a python.org feature to make the paths uicode
which changes the WIN32 API used. The default WIN32 is limited
to file lengths of 256 characters.
The testing of building on Windows is done using MSYS2.
Remove the extra gdb-7.8.1.cfg and added support to allow GDB tar
compression to be version defined. GDB has changed it default to .xz.
Thanks to Wendell P Silva for the excellent Wiki page.
https://developers.google.com/protocol-buffers/
Adding the host name results in the tar files created by the
--bset-tar-file and --pkg-tar-files to contain the host name.
This is useful when building Cxc packages.
