Close #3286
The building of 3rd party packages for an RTEMS BSP requires a valid
BSP so the standard method to download the source for releasing does
not work. This change adds support to allow this. The RTEMS BSP support
will not generate an error is no BSP or tools are provided or found.
The change addis logic operators to the %if statement so you can '||'
to 'or' and '&&' to 'and' logic expressions.
A new %log directive has been added to clean up the messages.
A new %{!define ...} has been added to aid checking within logic
expressions.
All command line --with/--without now appear as macros.
Add version.version to get just the RTEMS major and minor version.
Some pkg-config issues have been resolved.
Closes #2655.
The default without the option is to prepend the release URL to the URL
list to download from the RTEMS FTP site first if the RSB is released. This
option can force the RTEMS FTP to be tried first when not a release,
or you can supply a different URL to download from or you can request
no RTEMS URL is tried first. Eg:
--with-release-url
--with-release-url=file://opt/local/cache
--without-release-url
Move the RTEMS release URL to the default.mc file. Change the URL
to the RTEMS FTP server and do not use the https method of access.
The option's with_arg call was cleaned up to make sense.
Remove the log's raw output of an extra space.
Some download error message formating was cleaned up.
Closes #2636.
Fix Windows support to allow MSYS2 Python to be used.
Updates #2619.
VERSION is an INI format file with 2 sections:
1. version
The version of the release. It contains:
release = version-string
2. hashes
A list of hashes for packages that are formed when creating a release.
A hash entry is:
file-name = hash-type checksum
The approach means we do not need to hold hash values in configuration files
which need to be updated when a release is made. The release scripts can
generate the hashes when creating the release.
Update the version to 4.12.
Add a --without-error-reports flags to reduce the noise on --with-downloading.
Add support to release the RSB by adding the VERSION file. The file
is a single line with the version.
Fix the reports to include the version. Update the INI file
support to include the details of the build.
Show the GIT or released version when the command starts.
Closes #2480.
The change fixes installing for RTEMS 3rd Party packages where the
RSB considered them Canadian Cross Compiling (Cxc). Fixing the
Cxc issue broke real Cxc builds. The change corrects the issue of
macros being changed in the Cxc and the prep data not being udpated.
The configuration is loaded again after the updated macros. The
macros are also copied and restored to ensure a clean stable base.
The change also introduces --rtems-tools and --rtems-bsp to align
the command line with the waf configure process or RTEMS application.
This reverts commit 83d97daa070d67d177b90796ed22e4044ec9012c.
It contains a GPL license.
The --with/--without that does not have an extra option was
consuming an extra option on the command line.
support.
You can now test downloading by using --dry-run and --with-download.
Print the redirect if one is taken.
This is similar to always providing --no-install on the command when building
a Cxc package.
Generate an error report users can send to the mailing list with
error details.
Provide a log_info method for the options class to log the command line
and the python version string.
This changes adds support to build the autotools if the host installed
version is not a suitable version. Autoconf and automake have hard coded
references to the install prefix and host tools and this makes it impossible
to relocate, that is use in any path other than the install prefix. To
bootstrap automake you need to first build a suitable autoconf and with that
you can built automake for the install prefix. The other complication is
not referencing the install prefix in the path when building in the RSB.
Having the install prefix in the path can result in strange issues appearing
such as gcc using a new assembler feature not present in an older assember
installed under the install prefix.
The process is to build the autotools using an install prefix to an
internal path inside the RSB temporary path and to use that autoconf
to build the version for the install prefix. The internal install
prefix version is also used to bootstrap RTEMS.
Rework the RTEMS build set files to point to the new location.
Move the files into devel, this follows the ports naming in
FreeBSD.
Update the macros, defaults, and options to support this.
Fix paths that need to be coverted to host format.
The shell expansion needs to invoke a shell on Windows as cmd.exe
will not work.
Munch the paths into smaller sizes for Windows due to the limited
path size.
Added a check in the options post processing to check is the
prefix path allows writes. No actual write check is made. just
the permissions are checked. If the --no-install options is
used the check is not made.
Moved the --no-install option from the set builder to the options
module.
To support building snapshots and pre-release source the defaults
has been refactored. The defaults have been moved to a stand alone
file and a macros.py module added. This modile abstracts the
old default dictionary turning it into a class. The macros
class can load macros from a file therefore the defaults have
been moved to a stand alone file.
The use of defaults has been removed from the project. The only
case where it is used in the options where the defaults are read
from a file. Macros are used everywhere now.
The defaults.py has been moved to the option.py and the separate
options and defaults values has been moved to a new pattern. When
constructing an object that needs macros and options if the macros
passed in is None the defaults from the options are used. This makes
it clear when the defaults are being used or when a modified set of
macros is being used.
The macros class support maps. The default is 'global' and where all
the defaults reside and where configuratiion file changes end up.
Maps allow macros to be read from a file and override the values
being maintained in the 'global' map. Reading a macro first checks
the map and if not present checks the 'global' map.
The addition of maps to the macros provides the base to support
snapshots and pre-release testing with standard configurations.
This functionality needs to be added. It works by letting to
specify a snapshot with:
source0: none, override, 'my-dist.tar.bz2'
and it will be used rather the value from the standard configuration.
With a build set you need to also specify the package these macros
are for. The maps provide this.
