* | config: Fix the host and build options for Canadian cross builds. | Chris Johns | 2014-05-04 | 1 | -19/+19 |
| | | | | | | The ARM on 4.9.0 with clang fails and needs an extra option and this is only valid building the build cross compiler. This change fxies the host and build flags so they only apply where needed. | ||||
* | sb: Add _host_os_version to all supported hosts. | Chris Johns | 2014-04-10 | 1 | -18/+19 |
* | sb: Add include/lib paths for /usr/pkg to NetBSD. | Chris Johns | 2013-09-10 | 1 | -0/+1 |
* | sb: Add NetBSD support. | Ivan Temp | 2013-09-01 | 1 | -0/+90 |
