2020-08-28 | sb: Fix the imports on Python2 | Chris Johns | 1 | -2/+0 | |
Updates #4037 | |||||
2020-08-25 | sb: Use shebang env python | Chris Johns | 1 | -10/+14 | |
Closes #4037 | |||||
2018-10-21 | sb: Add support to search for a suitable version of python. | Chris Johns | 1 | -14/+10 | |
The command python has been removed from upstream python and python2 and python3 is now used. This patch wraps the commands in a shell script that locates a suitable python to run. Updates #3537 | |||||
2016-03-07 | sb: Update code base to support Python3 and Python2. | Chris Johns | 1 | -1/+3 | |
Fix Windows support to allow MSYS2 Python to be used. Updates #2619. | |||||
2012-11-06 | Move into the source-builder tree. | Chris Johns | 1 | -0/+0 | |
2012-11-04 | Set execute perms. | Chris Johns | 1 | -0/+0 | |
2012-11-04 | Add checking support to make sure a host is setup correctly. | Chris Johns | 1 | -2/+2 | |
2012-10-31 | Change name to Source Builder from Tool Builder. | Chris Johns | 1 | -4/+4 | |
