The building of 3rd party packages for an RTEMS BSP requires a valid
BSP so the standard method to download the source for releasing does
not work. This change adds support to allow this. The RTEMS BSP support
will not generate an error is no BSP or tools are provided or found.
The change addis logic operators to the %if statement so you can '||'
to 'or' and '&&' to 'and' logic expressions.
A new %log directive has been added to clean up the messages.
A new %{!define ...} has been added to aid checking within logic
expressions.
All command line --with/--without now appear as macros.
Add version.version to get just the RTEMS major and minor version.
Some pkg-config issues have been resolved.
Closes #2655.
Closes #2645.
Fix Windows support to allow MSYS2 Python to be used.
Updates #2619.
Remove the 'opt' from various macros and shell variables.
Add pkgconfig to the checks to make it clear the check is a
pkgconfig check.
Add NTP support as the first package to be built using the RSB.
Split the RTEMS URL's out from the base bset file into a separate
file that be included by other files.
Add an RTEMS BSP configuration file to help abstract the process
of building 3rd party packages.
Clean the cross and canadian cross support up so we can cleanly support
cross and canadian cross building.
Refactor the pkgconfig support and clean up the PC file handling of
loading modules.
Add support for %{?..} to return false if a macro is %{nil}.
Add %{pkgconfig ..} support to allow better control of access RTEMS
pkgconfig files.
Hack round the FreeBSD iconv support in Freebsd 10. In 10 libc now
supports iconv however iconv.h is present under /usr/local.
Start to add support to build qemu for MinGW via a Cxc. This is a
work in progress and contains lots of hidden traps.
In config.py separate out of the canadian build status.
Include the argparse package in the source and use if not available.
Add a pkg-config look alike command so packages that use pkg-config can
build if pkg-config is not present on a host.
Add support to query package config from configuration scripts.
