- Build GDb first as we do for RTEMS 5 and later
- Update GDB to 9.1 for all archs expect SPARC. The SIS patches
only apply to 7.9. Disable Python for SPARC
Closes #4111
Remove the numbered source and patches and automatically manage
sources and patches. This removes the overhead in maintaining large
collections of patches.
Hack round the FreeBSD iconv support in Freebsd 10. In 10 libc now
supports iconv however iconv.h is present under /usr/local.
Start to add support to build qemu for MinGW via a Cxc. This is a
work in progress and contains lots of hidden traps.
In config.py separate out of the canadian build status.
Update configuration to build on FreeBSD. This is based on pkg-config
detecting the packages installed on the host.
Qemu requires gettext, glib, libffi, and pixman. DTC is built
as a submodule.
On Mavrick provide a pkg-config command so avoid needing a pkgconfig.
The one here is only just good enough to work.
Provide an internal autotools build including libtool so qemu can
be built from git.
