path: root/source-builder/config/gdb-6-1.cfg (follow)
* Add the host name to the package name.Chris Johns2015-01-181-1/+1
| | | | | | Adding the host name results in the tar files created by the --bset-tar-file and --pkg-tar-files to contain the host name. This is useful when building Cxc packages.
* sb: Add support for building RTEMS 3rd party packages.Chris Johns2014-06-151-1/+1
| | | | | | | | | | | | | | | | | | | | | | | | | | Remove the 'opt' from various macros and shell variables. Add pkgconfig to the checks to make it clear the check is a pkgconfig check. Add NTP support as the first package to be built using the RSB. Split the RTEMS URL's out from the base bset file into a separate file that be included by other files. Add an RTEMS BSP configuration file to help abstract the process of building 3rd party packages. Clean the cross and canadian cross support up so we can cleanly support cross and canadian cross building. Refactor the pkgconfig support and clean up the PC file handling of loading modules. Add support for %{?..} to return false if a macro is %{nil}. Add %{pkgconfig ..} support to allow better control of access RTEMS pkgconfig files.
* sb: Implement %source and %patch to manage source and patches.Chris Johns2014-05-131-15/+3
| | | | | | Remove the numbered source and patches and automatically manage sources and patches. This removes the overhead in maintaining large collections of patches.
* Add RTEMS 4.9 support for i386 and SPARC.Chris Johns2013-03-151-0/+81
