- Build GDb first as we do for RTEMS 5 and later
- Update GDB to 9.1 for all archs expect SPARC. The SIS patches
only apply to 7.9. Disable Python for SPARC
Closes #4111
Using the RSB release version for the gcc version string means the
tools have a version string that matches the release.
Close #3074
Newer makeinfo tools cannot build the existing texinfo in gcc so
disable building it. This will not be fixed on the gcc branches.
Updates #3027.
The testing of building on Windows is done using MSYS2.
Adding the host name results in the tar files created by the
--bset-tar-file and --pkg-tar-files to contain the host name.
This is useful when building Cxc packages.
Remove the numbered source and patches and automatically manage
sources and patches. This removes the overhead in maintaining large
collections of patches.
On NetBSD with ksh changing into a symlink made PWD the link's
target path so a 'cd ..' returned you to that parent and not
the parent you started from. Record the build top and then
change back to that path.
Change the package names to the actual packages and remove the
extra directory in the build tree. This makes the paths simpler.
Turn off iconv support for the AVR because the arrays are too big.
Set up the rules to manage the separate host and build setting to
allow a Canadian cross to complete.
Update the scripts to move the build directory and host/build
flags into the defaults so they are common for all build
configurations.
These changes complete the CVS download support.
Add support to use a git cloned repo as the source. Move the download
code out of the build module and into a separate module. Add to this
module support for git.
Update the GCC common configuration to support using a symlinked
git repo.
Add checks for all languages.
Add support to build MinGW tools using Cygwin. This is a Canadian cross
build.
Do not expand the directives when parsing a configuration file. Hold
in the package object the text as read from the configuration file. Still
parse the logic but leave the macros. This allows a configuration to be
varied when the build happens. The Canadian cross uses this to build a
build compiler used to build a Cxc runtime.
Add Cxc support to the build module. In the defaults add rm and rmfile
macros, add Cxc paths and pre-build script code.
In the setbuilder check for a Cxc build and if so and the package
allow Cxc build the build host version then the host target
version.
Add cygiwn support to the defaults processing and to the Windows module.
