* | Update the GCC component paths to ones master uses | Chris Johns | 2022-01-24 | 1 | -2/+2 |
| | | | | Closes #4584 | ||||
* | sb: Back port the RTEMS 5 and 6 RSB engine. | Chris Johns | 2020-10-06 | 1 | -4/+4 |
| | | | | | | | | | - Build GDb first as we do for RTEMS 5 and later - Update GDB to 9.1 for all archs expect SPARC. The SIS patches only apply to 7.9. Disable Python for SPARC Closes #4111 | ||||
* | gcc: Use GNU's FTP rather than the package's home sites that change. | Chris Johns | 2018-01-18 | 1 | -3/+3 |
| | | | | Close #3271 | ||||
* | sb: Implement %source and %patch to manage source and patches. | Chris Johns | 2014-05-13 | 1 | -15/+5 |
| | | | | | | Remove the numbered source and patches and automatically manage sources and patches. This removes the overhead in maintaining large collections of patches. | ||||
* | config: Add gcc-4.9.0 configuration support. | Chris Johns | 2014-05-08 | 1 | -0/+41 |
