- Build GDb first as we do for RTEMS 5 and later
- Update GDB to 9.1 for all archs expect SPARC. The SIS patches
only apply to 7.9. Disable Python for SPARC
Closes #4111
Close #3271
Remove the numbered source and patches and automatically manage
sources and patches. This removes the overhead in maintaining large
collections of patches.
Add support to build MinGW tools using Cygwin. This is a Canadian cross
build.
Do not expand the directives when parsing a configuration file. Hold
in the package object the text as read from the configuration file. Still
parse the logic but leave the macros. This allows a configuration to be
varied when the build happens. The Canadian cross uses this to build a
build compiler used to build a Cxc runtime.
Add Cxc support to the build module. In the defaults add rm and rmfile
macros, add Cxc paths and pre-build script code.
In the setbuilder check for a Cxc build and if so and the package
allow Cxc build the build host version then the host target
version.
Add cygiwn support to the defaults processing and to the Windows module.
This is the reported known working tool set by the Milkymist project.
Currently this does not build on MacOS. It could be a host issue with
the age of the compiler.
