* | 6/7: Use TLS in Newlib for some targets by default | Sebastian Huber | 2022-07-21 | 12 | -0/+12 |
| | | | | | | | | Use the --enable-newlib-reent-thread-local (_REENT_THREAD_LOCAL_STORAGE) Newlib configuration option on the aarch64, arm, nios2, powerpc, riscv, and sparc targets by default. Update #4560. | ||||
* | 6/7: Update Newlib | Sebastian Huber | 2022-07-21 | 4 | -7/+33 |
| | | | | | | | This makes the --enable-newlib-reent-thread-local (_REENT_THREAD_LOCAL_STORAGE) Newlib configuration option available. Update #4560. | ||||
* | gcc12/libstdc++: Fix lifetime bugs for non-TLS eh_globals | Chris Johns | 2022-07-06 | 1 | -8/+21 |
| | | | | | | | - This is the fix from PR105880: https://gcc.gnu.org/bugzilla/attachment.cgi?id=53103 Closes #4661 | ||||
* | 7: Update Binutils, GDB, and GCC | Sebastian Huber | 2022-07-01 | 3 | -6/+6 |
* | 6/7: Update Newlib | Sebastian Huber | 2022-07-01 | 3 | -6/+6 |
| | | | | | | This Newlib update fixes a FreeBSD kernel space issue with <sys/cpuset.h>. Update #4667. | ||||
* | 6: Add GCC 10.4 with Newlib e7ffbdb | Sebastian Huber | 2022-06-29 | 1 | -0/+27 |
* | 6: Back port v8 of gcov improvements to GCC 10 | Sebastian Huber | 2022-06-29 | 1 | -2/+2 |
| | | | | Update #4196. | ||||
* | 6/7: Update Newlib | Sebastian Huber | 2022-06-24 | 3 | -6/+6 |
| | | | | | | This Newlib update fixes a namespace pollution issue with <sys/bitset.h>. Close #4667. | ||||
* | 6: Update GCC 10 and 12 | Sebastian Huber | 2022-06-22 | 2 | -4/+4 |
* | 6: Back port v6 of gcov improvements to GCC 10 | Sebastian Huber | 2022-06-21 | 1 | -2/+2 |
* | 6/tools: Update to the latest commit | Chris Johns | 2022-05-18 | 1 | -2/+2 |
* | ISL, MPC, MPFR: fix configuration issues on ARM64/Darwin host | Karel Gardas | 2022-05-17 | 1 | -0/+14 |
| | | | | | | Updates #4657. Sponsored-By: Precidata | ||||
* | 7: Remove superfluous GCC patch | Sebastian Huber | 2022-05-09 | 1 | -3/+0 |
* | 7: Update Binutils, GDB, and GCC | Sebastian Huber | 2022-05-09 | 3 | -6/+6 |
* | 6: Update to GCC 12 | Sebastian Huber | 2022-05-09 | 2 | -1/+27 |
* | sb/setbuilder: Control buildsets using the --with-* command line option | Chris Johns | 2022-05-05 | 3 | -22/+42 |
| | | | | | | | | | | - Expand macros in buildset file names - Add support to buildsets for `%defineifnot` - Update 6 and 7 to support command line build overrides Closes #4646 | ||||
* | 7: Back port gcov-tool merge-stream to GCC 12 | Sebastian Huber | 2022-05-04 | 1 | -0/+3 |
* | 7: Update Binutils, GDB, and GCC | Sebastian Huber | 2022-05-04 | 3 | -6/+6 |
* | 7: Update Binutils, GDB, and GCC | Sebastian Huber | 2022-04-27 | 3 | -6/+6 |
* | 6/7: Use gmp-6.2.1 for GDB | Sebastian Huber | 2022-04-25 | 3 | -3/+3 |
* | 6/7: Use expat-2.4.8 | Sebastian Huber | 2022-04-25 | 2 | -2/+2 |
* | 6: update default set to use expat 2.4.8 | Karel Gardas | 2022-04-22 | 1 | -1/+1 |
| | | | | | This solves issues with compilation on aarch64-linux platform since it is not recognized by previous expat 2.1.0. | ||||
* | 6/7: Update GCC prerequisites for GCC 10 and 12 | Sebastian Huber | 2022-04-22 | 2 | -2/+2 |
* | 7: Update Binutils, GCC, and GDB | Sebastian Huber | 2022-03-22 | 3 | -6/+6 |
* | 6/7: Update Newlib | Sebastian Huber | 2022-03-22 | 2 | -4/+4 |
| | | | | | | Fix the iconv support to avoid linker errors like this: newlib/libc/iconv/lib/ucsconv.c:66: undefined reference to `_iconv_to_ucs_ces' | ||||
* | 6/7: Update Newlib | Sebastian Huber | 2022-03-18 | 2 | -4/+4 |
| | | | | The update of the Newlib build system seems to be finished. | ||||
* | 6/7: Update AArch64 newlib patch | Kinsey Moore | 2022-03-18 | 2 | -4/+4 |
| | | | | | The existing patch fails to build with the latest newlib. This picks up an updated patch that compiles with both older and newer newlib. | ||||
* | microblaze: Add GCC patch to define __ELF__ | Alex White | 2022-03-09 | 1 | -0/+3 |
| | | | | This fixes compilation errors in rtems-libbsd. | ||||
* | 6/7: Update Newlib | Sebastian Huber | 2022-03-09 | 2 | -4/+4 |
| | | | | This fixes an issue for some awk versions. | ||||
* | 7: Update Binutils, GDB, and GCC | Sebastian Huber | 2022-02-26 | 3 | -6/+6 |
* | 6/7: Update Newlib | Sebastian Huber | 2022-02-26 | 2 | -4/+4 |
* | 6: Use GDB 11.2 for mipstx39 | Sebastian Huber | 2022-02-26 | 2 | -1/+4 |
* | 6: Use GDB 11.2 | Sebastian Huber | 2022-02-24 | 3 | -2/+14 |
* | 6: Use Binutils 2.38 | Sebastian Huber | 2022-02-24 | 2 | -1/+13 |
* | 6: Update GCC to include a fix for powerpc | Sebastian Huber | 2022-02-24 | 1 | -2/+2 |
| | | | | https://gcc.gnu.org/bugzilla/show_bug.cgi?id=104090 | ||||
* | rtems-tools-6.cfg: Bump hash to get align option | Christian Mauderer | 2022-02-15 | 1 | -2/+2 |
* | rtems-tools-6.cfg: Bump hash | Ryan Long | 2022-01-31 | 1 | -2/+2 |
* | rtems-tools-6.cfg: Bump hash to get new INI files | Ryan Long | 2022-01-21 | 1 | -2/+2 |
* | Update Newlib for powerpc/setjmp improvements | Sebastian Huber | 2022-01-11 | 2 | -4/+4 |
* | 6: Update GCC to fix PR100108 | Sebastian Huber | 2021-12-14 | 1 | -2/+2 |
| | | | | | | | This update fixes a GCC 10 regression which resulted in invalid code generation for some 32-bit powerpc targets: https://gcc.gnu.org/bugzilla/show_bug.cgi?id=100108 | ||||
* | RSB: update dtc 1.6.0 -> dtc 1.6.1 | Karel Gardas | 2021-11-18 | 2 | -2/+2 |
| | | | | | | | | Fixes #4221 Note: the patch updates only dtc 1.6.0 occurrences. It leaves all other dtc (1.4.x) usages as they are just to not break anything which depends on older dtc versions. | ||||
* | RSB: fix hash setup for binutils 2.37 | Karel Gardas | 2021-11-18 | 1 | -1/+1 |
* | RSB: add GRUB2 to the RTEMS tools and use it in 6/rtems-x86_64 build set | Karel Gardas | 2021-11-18 | 2 | -0/+13 |
* | rtems-tools-6.cfg: Bump hash to get fix for rtems-test | Joel Sherrill | 2021-11-12 | 1 | -2/+2 |
* | config/[67]/rtems-*.bset: Move dtc to default set | Joel Sherrill | 2021-11-09 | 5 | -4/+4 |
* | rtems-tools-6.cfg: Bump rtems-tools hash | Joel Sherrill | 2021-11-09 | 1 | -2/+2 |
* | rtems-kernel: Implement kernel recipe using waf | Ryan Long | 2021-11-09 | 2 | -63/+68 |
| | | | | Closes #4145 | ||||
* | rtems-gcc-10-newlib-head: Uncomment patch lines | Kinsey Moore | 2021-11-05 | 1 | -2/+2 |
| | | | | | | These lines were accidentally committed with a leading + which resulted in them being non-functional. This restores them to functionality such that the patch gets downloaded and applied appropriately. | ||||
* | rtems-tools-6.cfg: Bump hash to include MicroBlaze | Alex White | 2021-10-25 | 1 | -2/+2 |
| | | | | Hash: 323007a6b520140a20b2e268c90b78ff67afaf45 |
