* | Revert "x86_64/gcc: Add gcc patch for LIB_SPEC (rtems.h in gcc)" | Chris Johns | 2018-05-04 | 1 | -3/+0 |
| | | | | This reverts commit 8e763905381755ec2e421bb50d92166cc7fd8ec5. | ||||
* | x86_64/gcc: Add gcc patch for LIB_SPEC (rtems.h in gcc) | Amaan Cheval | 2018-05-04 | 1 | -0/+3 |
| | | | | | | | | Adds -qnolinkcmds, -qrtems, and defaults to pass to linker, for gcc targeting x86_64. Corresponding gcc commit: https://gcc.gnu.org/git/?p=gcc.git;a=commit;h=602fa1e9d3ea5e87d4d6e17e3e91fc2647e42da3 | ||||
* | rtems-tools: Update to pick up the --enable-rtems-debug fix. | Chris Johns | 2018-04-24 | 1 | -2/+2 |
* | 5: Use a specific RTEMS tools version | Sebastian Huber | 2018-04-18 | 2 | -6/+34 |
| | | | | | | Download via cgit archive. Close #3403. | ||||
* | gcc: Use the RSB release for released tools. | Chris Johns | 2018-02-07 | 1 | -1/+2 |
| | | | | | | | Using the RSB release version for the gcc version string means the tools have a version string that matches the release. Close #3294 | ||||
* | 5: Add versions to file names | Sebastian Huber | 2018-01-31 | 10 | -12/+12 |
* | 5: Update to Binutils 2.30 | Sebastian Huber | 2018-01-29 | 7 | -6/+33 |
* | 5: Update to Newlib 3.0.0 and GCC 7.3 | Sebastian Huber | 2018-01-26 | 9 | -14/+50 |
| | | | | | Epiphany target can now use the default build set. The or1k and m32c targets still need special GCC versions. | ||||
* | 5: Update SPARC chip errata workarounds | Sebastian Huber | 2017-12-19 | 1 | -2/+2 |
| | | | | Update #3242. | ||||
* | 5: Ada: Fix more POSIX types | Sebastian Huber | 2017-12-04 | 1 | -2/+2 |
| | | | | Update #3256. | ||||
* | 5: Ada: Fix some POSIX types | Sebastian Huber | 2017-12-01 | 1 | -0/+3 |
| | | | | Close #3256. | ||||
* | 5: Add SPARC chip errata workarounds | Sebastian Huber | 2017-11-30 | 1 | -0/+3 |
| | | | | Close #3242. | ||||
* | 5/rtems-all.bset: Add missing aarch64 | Joel Sherrill | 2017-11-12 | 1 | -0/+1 |
| | | | | closes #3227. | ||||
* | 5: Update to special MIPS GDB to 8.0.1 | Sebastian Huber | 2017-11-10 | 2 | -1/+4 |
* | 5: Avoid rtems-tools for epiphany GDB | Sebastian Huber | 2017-11-10 | 1 | -2/+2 |
| | | | | Close #3226. | ||||
* | 5: Use custome GDB 7.11 without for or1k | Sebastian Huber | 2017-11-10 | 2 | -1/+21 |
| | | | | Do not include aarch64 and SPARC patches. | ||||
* | 5: Upgrade m32c to GDB 8.0.1 | Sebastian Huber | 2017-11-10 | 1 | -1/+1 |
| | | | | Close #3225. | ||||
* | 5: Use Binutils 2.29 for or1k and m32c | Sebastian Huber | 2017-11-10 | 2 | -2/+2 |
| | | | | | | This avoids Binutils patches from rtems-tools. Close #3224. | ||||
* | 5: Use ticket attachment for automake patch | Sebastian Huber | 2017-11-10 | 1 | -1/+1 |
| | | | | Update #2616. | ||||
* | 5: Add Newlib patches | Sebastian Huber | 2017-11-09 | 6 | -0/+36 |
| | | | | | Update #3185. Close #3189. | ||||
* | Change RTEMS version from 4.12 to 5 | Sebastian Huber | 2017-11-09 | 36 | -91/+91 |
| | | | | Update #3220. | ||||
* | 4.12: Add x86_64 and RISCV64 to 4.12/rtems-all. | Chris Johns | 2017-10-31 | 1 | -0/+2 |
* | sb: Provide a more detail email message. | Chris Johns | 2017-10-27 | 1 | -0/+5 |
| | | | | Close #3210. | ||||
* | RSB - Add support for RISC-V RV64 (64-bit) toolchain v2 | Hesham Almatary | 2017-10-27 | 1 | -0/+16 |
| | | | | Update #3109 | ||||
* | rtems-epiphany.bset: Add sha512sum for GCC git repository | Joel Sherrill | 2017-10-23 | 1 | -1/+1 |
| | | | | Closes #3201. | ||||
* | rtems-gdb-7.11-1.cfg: Correct sha512sum on gdb-7.11-sis-leon2-leon3.diff | Joel Sherrill | 2017-10-23 | 1 | -1/+1 |
| | | | | Closes #3202. | ||||
* | 4.12: Fix the nios2 spelling in the tier-3 build set. | Chris Johns | 2017-10-23 | 1 | -1/+1 |
* | 4.12: Add tier build sets to aid regression testing. | Chris Johns | 2017-10-23 | 4 | -0/+36 |
* | 4.12: Update all MD5 hashes to SHA256. | Chris Johns | 2017-10-12 | 10 | -24/+27 |
| | | | | Closes #2536. | ||||
* | Enable 64-bit BFD support. Needed on 32bit hosts | Joel Sherrill | 2017-10-11 | 1 | -0/+5 |
| | | | | Closes #3157. | ||||
* | rtems-sh.bset: Use default toolset specifically GCC 7 | Joel Sherrill | 2017-10-11 | 1 | -14/+1 |
| | | | | Closes #3178. | ||||
* | rtems-moxie.bset: Add revision | Joel Sherrill | 2017-10-11 | 1 | -0/+1 |
| | | | | Closes #3046. | ||||
* | 4.12: Update to Newlib 2.5.0.20170922 | Sebastian Huber | 2017-10-05 | 12 | -6/+148 |
| | | | | | | | | | | | | | | | The time_t is now a 64-bit signed integer. This update includes a patch to introduce the self-contained POSIX synchronization objects. Update #2514. Update #3111. Update #3112. Update #3113. Update #3114. Update #3115. Update #3116. | ||||
* | mips: Use the FreeBSD fix for Darwin MIP tools build. | Chris Johns | 2017-09-10 | 1 | -1/+1 |
| | | | | Closes 3127. | ||||
* | 4.12: Update to GDB 8.0.1 | Sebastian Huber | 2017-09-08 | 3 | -2/+17 |
* | 4.12: Change clock_t to 64-bit | Sebastian Huber | 2017-08-25 | 6 | -0/+30 |
| | | | | | Update #2135. Update #3111. | ||||
* | 4.12: Add riscv32 to all | Sebastian Huber | 2017-08-23 | 1 | -0/+1 |
| | | | | Update #3109. | ||||
* | 4.12: Fix 64-bit PowerPC support of GCC 7.2 | Sebastian Huber | 2017-08-22 | 1 | -0/+4 |
| | | | | Update #3082. | ||||
* | 4.12: Add basic RISC-V tool chain | Sebastian Huber | 2017-08-22 | 2 | -0/+19 |
| | | | | | GDB is not included. This probably needs some patches or an update to GDB 8.0. | ||||
* | 4.12: Update to GCC 7.2 | Sebastian Huber | 2017-08-22 | 2 | -1/+29 |
* | 4.12: Update to Newlib 2.5.0.20170818 | Sebastian Huber | 2017-08-22 | 8 | -4/+56 |
* | Update to the newlib snapshot 20170818. | Chris Johns | 2017-08-21 | 2 | -1/+38 |
* | 4.12: Fix for Binutils PR21884 | Sebastian Huber | 2017-08-10 | 1 | -0/+3 |
| | | | | | | See https://sourceware.org/bugzilla/show_bug.cgi?id=21884. Close #3091. | ||||
* | 4.12/lm32: Fix building on Windows. | Chris Johns | 2017-08-09 | 1 | -0/+7 |
| | | | | | | This patch fixes building the LM32 GDB on Windows. Closes #3030. | ||||
* | 4.12/gcc-4.8.3 Fix building with a newer version of gcc. | Chris Johns | 2017-08-09 | 1 | -0/+14 |
| | | | | Updates #2990. | ||||
* | gcc: Disable makeinfo cause newer versions do not build gcc-4.8 docs. | Chris Johns | 2017-08-09 | 1 | -0/+2 |
| | | | | | | | Newer makeinfo tools cannot build the existing texinfo in gcc so disable building it. This will not be fixed on the gcc branch. Updates #3027. | ||||
* | 4.12: Update to Newlib 2.5.0.20170720 | Sebastian Huber | 2017-08-08 | 10 | -5/+111 |
* | 4.12: Fix SIS patch URL | Sebastian Huber | 2017-07-31 | 1 | -1/+1 |
* | RSB: Update gdb-7.12 config to pull in latest sis patches | Jiri Gaisler | 2017-07-31 | 1 | -1/+1 |
| | | | | | | | | | | | Please merge. From b14821b4ac72913139cc1758e9757443f697a642 Mon Sep 17 00:00:00 2001 From: Jiri Gaisler <jiri@gaisler.se> Date: Sun, 30 Jul 2017 21:27:38 +0200 Subject: [PATCH] Update gdb-7.12 config to pull in latest sis patches. * Will make sure sis uses LMA rather than VMA when loading elf files. | ||||
* | 4.12: Update to Binutils 2.29 | Sebastian Huber | 2017-07-28 | 3 | -2/+24 |
| | | | | Update #3082. |
