* | 6: Update tool chain | Sebastian Huber | 2021-03-16 | 3 | -6/+6 |
* | Add recipe for building rtems-net-legacy | Vijay Kumar Banerjee | 2021-03-10 | 3 | -0/+94 |
* | 7: Update tool chain | Sebastian Huber | 2021-03-09 | 3 | -8/+8 |
* | 6: Update tool chain | Sebastian Huber | 2021-03-09 | 3 | -8/+8 |
* | 7: Update tool chain | Sebastian Huber | 2021-03-08 | 3 | -8/+8 |
* | 6: Update tool chain | Sebastian Huber | 2021-03-08 | 3 | -8/+8 |
* | 7: Update tool chain | Sebastian Huber | 2021-03-05 | 3 | -8/+8 |
* | 6: Update tool chain | Sebastian Huber | 2021-03-05 | 3 | -8/+8 |
* | 7: Update tool chain | Sebastian Huber | 2021-02-05 | 3 | -8/+8 |
* | 6: Update tool chain | Sebastian Huber | 2021-02-05 | 3 | -8/+8 |
* | 6: Update tool chain | Sebastian Huber | 2021-01-26 | 3 | -8/+8 |
| | | | | Close #3937. | ||||
* | 7: Update tool chain | Sebastian Huber | 2021-01-25 | 3 | -8/+8 |
* | 6: Use release branches for Binutils/GDB | Sebastian Huber | 2021-01-22 | 6 | -12/+35 |
* | 6/7: Update unstable RTEMS 6/7 tool chain | Sebastian Huber | 2021-01-21 | 4 | -12/+12 |
* | 6/7: Update unstable RTEMS 6/7 tool chain | Sebastian Huber | 2021-01-20 | 4 | -12/+12 |
* | 6: Add FPH2 multilib for nios2 | Sebastian Huber | 2021-01-17 | 1 | -0/+3 |
| | | | | Update #4215. | ||||
* | 6/7: Update unstable RTEMS 6/7 tool chain | Sebastian Huber | 2021-01-17 | 4 | -8/+8 |
* | 6/7: Update unstable RTEMS 6/7 tool chain | Sebastian Huber | 2021-01-14 | 4 | -12/+12 |
* | 6/7: Update unstable RTEMS 6/7 tool chain | Sebastian Huber | 2021-01-14 | 4 | -8/+8 |
* | 6/7: Update unstable RTEMS 6/7 tool chain | Sebastian Huber | 2021-01-04 | 4 | -8/+8 |
* | 6/7: Update to the latest rtems-tools | Sebastian Huber | 2021-01-04 | 1 | -2/+2 |
| | | | | Update #4202. | ||||
* | 6/7: Update unstable RTEMS 6/7 tool chain | Sebastian Huber | 2020-12-22 | 4 | -8/+8 |
* | 6/7: Update unstable RTEMS 6/7 tool chain | Sebastian Huber | 2020-12-21 | 4 | -12/+12 |
* | Add GMP as a prerequisite for GDB | Sebastian Huber | 2020-12-21 | 2 | -0/+2 |
* | 6/7: Update to the latest rtems-tools | Sebastian Huber | 2020-12-16 | 1 | -2/+2 |
* | 6/7: Update unstable RTEMS 6/7 tool chain | Sebastian Huber | 2020-12-15 | 2 | -8/+8 |
| | | | | | | This update includes a fix for the ARM Cortex-R52 support in Newlib. Update #4198. | ||||
* | 6/7: Add multilib for ARM Cortex-R52 processor | Sebastian Huber | 2020-12-03 | 2 | -4/+4 |
| | | | | Close #4198. | ||||
* | 6: Add support for gcov info section | Sebastian Huber | 2020-12-02 | 1 | -0/+3 |
| | | | | Update #4196. | ||||
* | 6/7: Update to the latest rtems-tools | Sebastian Huber | 2020-12-02 | 1 | -2/+2 |
| | | | | Close #4195. | ||||
* | 6/7: Update unstable RTEMS 6/7 tool chain | Sebastian Huber | 2020-12-01 | 2 | -8/+8 |
| | | | | Close #4193. | ||||
* | 6/7: Update unstable RTEMS 6/7 tool chain | Sebastian Huber | 2020-11-02 | 4 | -12/+12 |
* | 6/7: Update unstable RTEMS 6/7 tool chain | Sebastian Huber | 2020-10-28 | 4 | -12/+12 |
* | 6/7: Update unstable RTEMS 6/7 tool chain | Sebastian Huber | 2020-10-26 | 4 | -12/+12 |
* | 6/7: Update unstable RTEMS 6/7 tool chain | Sebastian Huber | 2020-10-12 | 5 | -16/+12 |
* | patch gcc i386 multiarch | Michael Davidsaver | 2020-09-21 | 1 | -0/+4 |
| | | | | | | | | | | | | Add patch to change from mtune to march when building multilibs. The mtune argument tunes or optimizes for a specific CPU model but does not ensure the generated code is appropriate for the CPU model. Prior to this patch, i386 compatible code was always generated but tuned for later models. This is the same fix as #2830 but applying to gcc 10. Updates #4084. | ||||
* | 6/7: Update unstable RTEMS 6/7 tool chain | Sebastian Huber | 2020-09-18 | 4 | -12/+12 |
* | 6: Update to the latest rtems-tools | Sebastian Huber | 2020-09-18 | 1 | -3/+2 |
* | Add sis to RISC-V build | Jiri Gaisler | 2020-09-10 | 1 | -0/+1 |
* | rtems: Update to the latest rtems-tools | Chris Johns | 2020-09-07 | 1 | -2/+3 |
* | 6/7: Update unstable RTEMS 6/7 tool chain | Sebastian Huber | 2020-09-04 | 4 | -12/+12 |
* | 6/7: Update unstable RTEMS 6/7 tool chain | Sebastian Huber | 2020-08-31 | 4 | -12/+12 |
* | Move 5 build sets to 6 | Chris Johns | 2020-08-13 | 59 | -423/+115 |
| | | | | | | | | | | - Move 5/bsps/* to bsps/* - Update package build references from 5 to 6 - Remove 5 build sets. Update #4048 | ||||
* | 6/7: Update unstable RTEMS 6/7 tool chain | Sebastian Huber | 2020-07-29 | 4 | -12/+12 |
* | rtems-tools: Pick up fix for modern llvm. | Christian Mauderer | 2020-07-23 | 1 | -2/+2 |
* | 6/7: Remove support for epiphany target | Sebastian Huber | 2020-07-05 | 3 | -19/+0 |
| | | | | Update #3941. | ||||
* | 6/7: Update unstable RTEMS 6/7 tool chain | Sebastian Huber | 2020-07-03 | 4 | -12/+12 |
* | moxie: Update to dtc 1.6.0 | Sebastian Huber | 2020-07-01 | 3 | -3/+3 |
| | | | | This fixes the build with a GCC 10 host compiler. | ||||
* | 6/7: Use RTEMS 6 tools | Sebastian Huber | 2020-06-30 | 4 | -3/+46 |
* | Make comment version independent | Sebastian Huber | 2020-06-30 | 1 | -1/+1 |
