In addition use Newlib snapshot 2.4.0.20160527.
graphics/nxlib is removed from build set because for actual Microwindows
the NXlib is included in Microwindows sources (src/nxlib).
The original NXlib libX11.a is replaced by two varinats
libPX11 links X11 server replacement directly to the application.
libNX11 is more X11 concept compatible, application and server
runs in the separate processes.
There has been collision between local extern excessive function
declaration and C library (newlib) provided header and type.
The support is added at the top level and so not lost when we
move to a new version of RTEMS.
The change also moves all 3rd party packages to use a common
rtems-package.bset build set file.
All packages except Microwindows itself build cleanly.
Move the 4.12 version and base defines to just RTEMS base defines
which includes the version. This removes the version from a number of
files and makes it simpler to move to a new version. It however means
we cannot support more than version on master.
This change further breaks 4.10 and 4.9 however it means we can
branch these versions and better support them on their branches.
Bump the OpenRISC toolchain to newer versions.
* Binutils to 2.26
* GCC to 4.9.3
* GDB to 7.11
updates #2669
The building of 3rd party packages for an RTEMS BSP requires a valid
BSP so the standard method to download the source for releasing does
not work. This change adds support to allow this. The RTEMS BSP support
will not generate an error is no BSP or tools are provided or found.
The change addis logic operators to the %if statement so you can '||'
to 'or' and '&&' to 'and' logic expressions.
A new %log directive has been added to clean up the messages.
A new %{!define ...} has been added to aid checking within logic
expressions.
All command line --with/--without now appear as macros.
Add version.version to get just the RTEMS major and minor version.
Some pkg-config issues have been resolved.
Closes #2655.
Updates #2649.
Updates #2644.
Also add:
--with-rtemsbsp="bsp,bsp,bsp"
--with-rtems-smp
--with-rtems-tests
--with-rtems-tests=sample
--with-rtems-tests=all
Closes #2526.
Provide without_release_url support in the configuration file so
the release tarball download of the kernel and tools uses the
release's top level directory and not the sources directory.
Closes #2481.
This is fixed by patch file gdb-7.3.1-rtems4.10-20151123.diff from the
rtems-tools.git repository.
Close #2524.
This is fixed by patch file gcc-core-4.4.7-rtems4.10-20151123.diff from the
Update #2524.
This is fixed by patch file binutils-2.20.1-rtems4.10-20151123.diff from the
Update #2524.
The default without the option is to prepend the release URL to the URL
list to download from the RTEMS FTP site first if the RSB is released. This
option can force the RTEMS FTP to be tried first when not a release,
or you can supply a different URL to download from or you can request
no RTEMS URL is tried first. Eg:
--with-release-url
--with-release-url=file://opt/local/cache
--without-release-url
Move the RTEMS release URL to the default.mc file. Change the URL
to the RTEMS FTP server and do not use the https method of access.
The option's with_arg call was cleaned up to make sense.
Remove the log's raw output of an extra space.
Some download error message formating was cleaned up.
Closes #2636.
Add support so 4.9 builds on a recent FreeBSD using clang.
Add the 4.9 newlib 1.16.0-20090324 patch.
Add a release to the 4.9 RTEMS kernel.
Add a release to the 4.10 RTEMS kernel.
Closes #2616.
Waf requires the drive be added to the destdir path so it installs to a path
the RSB knows. The RSB assumes the destdir contains an MSYS drive path as
seen in the POSIX path. This is default for configure scripts.
Also fix the git URL to pull before the branch command as well as after to
update the branch.
Closes #2605.
Use Binutils 2.26.
When rsb_released was not 0, a build failure would occur.
closes #2495.
Update to the GCC 6 20160124 snapshot, which notionally resolves
https://gcc.gnu.org/bugzilla/show_bug.cgi?id=65779
Add a --without-error-reports flags to reduce the noise on --with-downloading.
