* | rtems-gcc-10-newlib-head.cfg: Add newlib patch | Ryan Long | 2021-09-20 | 1 | -0/+3 |
| | | | | | | | | | Adds patch to add sanitation to the padding of bits and size_t types for AArch64 tools builds with newlib. These changes have been made in ARM, but newlib has yet to pull them. This can be removed once newlib has pulled the code. Updates #4510 | ||||
* | Remove automake/autoconf from rtems 6 tools | Joel Sherrill | 2021-09-18 | 5 | -49/+0 |
| | | | | | | These are unneeded with the waf build system. Closes #4081. | ||||
* | 6/rtems-tools: Update to rtems-test TFTP timeout fixes | Chris Johns | 2021-09-09 | 2 | -3/+4 |
| | | | | | | - Fix the 6/rtems-tools build set to use the correct tools version. - Tools version: 40a7058bd4d7681ca6be7a14f09a1275ea4fbde4 | ||||
* | rtems-tools-6.cfg: Correct checksum missing in previous patch | Joel Sherrill | 2021-09-07 | 1 | -1/+1 |
* | rtems-tools-6.cfg: Bump hash to include fixes for clang | Joel Sherrill | 2021-09-06 | 1 | -1/+1 |
| | | | | Hash: 9d399df4ef0050e9c190b38217b0e5d27dd0be72 | ||||
* | Update newlib to 9069cb9 hash | Joel Sherrill | 2021-09-02 | 2 | -4/+4 |
| | | | | | | | | This update is to include a fix for building rtems-libbsd using the previous newlib hash. <sys/signal.h> was using a macro specific to the newlib implementation of <stdint.h>. When building rtems-libbsd, -ffreestanding is used and that switches to the gcc <stdint.h> and there was a compilation error. | ||||
* | 6: Back port v5 of __gcov_info_to_gcda() to GCC 10 | Sebastian Huber | 2021-08-30 | 1 | -2/+2 |
| | | | | Update #4196. | ||||
* | rsb: Add MicroBlaze tools | Alex White | 2021-08-20 | 3 | -1/+108 |
* | rtems-tools-6.cfg: Bump to latest hash. | Joel Sherrill | 2021-08-18 | 1 | -2/+2 |
| | | | | Latest is 632414dc0f2976cc3ce0267d0c51aeb7c4de1e14 | ||||
* | rtems-gcc-10-newlib-head.cfg: Bump to latest hash (4f81149) | Joel Sherrill | 2021-08-18 | 1 | -2/+2 |
* | 6: Back port v3 of __gcov_info_to_gcda() to GCC 10 | Sebastian Huber | 2021-08-09 | 1 | -2/+2 |
* | 6: Back port v2 of __gcov_info_to_gcda() to GCC 10 | Sebastian Huber | 2021-08-09 | 1 | -2/+2 |
* | 6: Back port __gcov_info_to_gcda() to GCC 10 | Sebastian Huber | 2021-08-06 | 1 | -2/+2 |
| | | | | Close #4196. | ||||
* | rtems-binutils-head.cfg, rtems-gdb-head.cfg: Bump to 3b2bef8 | Joel Sherrill | 2021-05-21 | 2 | -4/+4 |
* | Bump newlib for rtems 6 and 7 to get UTIME_NOW and UTIME_OMIT constants. | Joel Sherrill | 2021-05-21 | 2 | -4/+4 |
* | 7: Update tool chain | Sebastian Huber | 2021-04-09 | 3 | -8/+8 |
* | 6: Update tool chain | Sebastian Huber | 2021-04-09 | 3 | -8/+8 |
* | 6/7: Update to the latest rtems-tools | Sebastian Huber | 2021-04-09 | 1 | -2/+2 |
* | 7: Update tool chain | Sebastian Huber | 2021-03-16 | 3 | -6/+6 |
* | 6: Update tool chain | Sebastian Huber | 2021-03-16 | 3 | -6/+6 |
* | Add recipe for building rtems-net-legacy | Vijay Kumar Banerjee | 2021-03-10 | 3 | -0/+94 |
* | 7: Update tool chain | Sebastian Huber | 2021-03-09 | 3 | -8/+8 |
* | 6: Update tool chain | Sebastian Huber | 2021-03-09 | 3 | -8/+8 |
* | 7: Update tool chain | Sebastian Huber | 2021-03-08 | 3 | -8/+8 |
* | 6: Update tool chain | Sebastian Huber | 2021-03-08 | 3 | -8/+8 |
* | 7: Update tool chain | Sebastian Huber | 2021-03-05 | 3 | -8/+8 |
* | 6: Update tool chain | Sebastian Huber | 2021-03-05 | 3 | -8/+8 |
* | 7: Update tool chain | Sebastian Huber | 2021-02-05 | 3 | -8/+8 |
* | 6: Update tool chain | Sebastian Huber | 2021-02-05 | 3 | -8/+8 |
* | 6: Update tool chain | Sebastian Huber | 2021-01-26 | 3 | -8/+8 |
| | | | | Close #3937. | ||||
* | 7: Update tool chain | Sebastian Huber | 2021-01-25 | 3 | -8/+8 |
* | 6: Use release branches for Binutils/GDB | Sebastian Huber | 2021-01-22 | 6 | -12/+35 |
* | 6/7: Update unstable RTEMS 6/7 tool chain | Sebastian Huber | 2021-01-21 | 4 | -12/+12 |
* | 6/7: Update unstable RTEMS 6/7 tool chain | Sebastian Huber | 2021-01-20 | 4 | -12/+12 |
* | 6: Add FPH2 multilib for nios2 | Sebastian Huber | 2021-01-17 | 1 | -0/+3 |
| | | | | Update #4215. | ||||
* | 6/7: Update unstable RTEMS 6/7 tool chain | Sebastian Huber | 2021-01-17 | 4 | -8/+8 |
* | 6/7: Update unstable RTEMS 6/7 tool chain | Sebastian Huber | 2021-01-14 | 4 | -12/+12 |
* | 6/7: Update unstable RTEMS 6/7 tool chain | Sebastian Huber | 2021-01-14 | 4 | -8/+8 |
* | 6/7: Update unstable RTEMS 6/7 tool chain | Sebastian Huber | 2021-01-04 | 4 | -8/+8 |
* | 6/7: Update to the latest rtems-tools | Sebastian Huber | 2021-01-04 | 1 | -2/+2 |
| | | | | Update #4202. | ||||
* | 6/7: Update unstable RTEMS 6/7 tool chain | Sebastian Huber | 2020-12-22 | 4 | -8/+8 |
* | 6/7: Update unstable RTEMS 6/7 tool chain | Sebastian Huber | 2020-12-21 | 4 | -12/+12 |
* | Add GMP as a prerequisite for GDB | Sebastian Huber | 2020-12-21 | 2 | -0/+2 |
* | 6/7: Update to the latest rtems-tools | Sebastian Huber | 2020-12-16 | 1 | -2/+2 |
* | 6/7: Update unstable RTEMS 6/7 tool chain | Sebastian Huber | 2020-12-15 | 2 | -8/+8 |
| | | | | | | This update includes a fix for the ARM Cortex-R52 support in Newlib. Update #4198. | ||||
* | 6/7: Add multilib for ARM Cortex-R52 processor | Sebastian Huber | 2020-12-03 | 2 | -4/+4 |
| | | | | Close #4198. | ||||
* | 6: Add support for gcov info section | Sebastian Huber | 2020-12-02 | 1 | -0/+3 |
* | 6/7: Update to the latest rtems-tools | Sebastian Huber | 2020-12-02 | 1 | -2/+2 |
| | | | | Close #4195. | ||||
* | 6/7: Update unstable RTEMS 6/7 tool chain | Sebastian Huber | 2020-12-01 | 2 | -8/+8 |
| | | | | Close #4193. | ||||
* | 6/7: Update unstable RTEMS 6/7 tool chain | Sebastian Huber | 2020-11-02 | 4 | -12/+12 |
