* | rtems: Add back gsed that was remove by mistake | Chris Johns | 2023-04-15 | 1 | -1/+2 | |
| | | | | | - Build GNU sed for hosts that it is not installed on for the MIPS tools. | |||||
* | print/texinfo: Add texinfo package | Chris Johns | 2023-04-12 | 1 | -3/+10 | |
| | | | | | | | | - MacOS systems do not come with makeinfo - Fix the internal build logic. There was config logic in a bset file that does not support logic operators. Use a special tmp internal path to isolate the internal tools. | |||||
* | rtems/microblaze: Update to GDB 13.1 | Chris Johns | 2023-04-05 | 1 | -1/+1 | |
| | | | | | | | | Note: GCC does not build on MacOS 13.3 due to the specific version of GCC the Microblaze is using. Updates #4892 | |||||
* | rtems/mipsstx39: Update to GDB 13.1 and stage build GMP | Chris Johns | 2023-04-05 | 9 | -54/+8 | |
| | | | | | | | - Use a build set file to stage GMP as recent GDB versions require GMP. Update #4892 | |||||
* | devel/mpfr: Update to 4.2.0 to support MacOS AARCH64 | Chris Johns | 2023-04-05 | 1 | -5/+2 | |
| | | | | | | | | - Use base64 checksums - Change MPFR URL Updates #4892 | |||||
* | gdb: Use a virtual environment if present | Chris Johns | 2023-04-05 | 1 | -0/+4 | |
| | | | | | | | | - Detect and use a virtual environment if present - Supports MacOS with python.org in a venv Updates #4892 | |||||
* | Revert binutils to 2.39 for rtems6 | Kinsey Moore | 2023-03-21 | 2 | -1/+14 | |
| | | | | | | | Binutils 2.40 has a regression for AArch64 that has previously been fixed. See https://sourceware.org/bugzilla/show_bug.cgi?id=27217 This regression causes at least 2 tests to fail to build. | |||||
* | rtems-tools-6.cfg: Update to get RISC-V bsp-builder corrections | Joel Sherrill | 2023-03-14 | 1 | -2/+2 | |
* | 6: Update MicroBlaze gdb to 12.1 | Alex White | 2023-03-13 | 1 | -1/+1 | |
| | | | | GDB 11.2 fails to compile on Ubuntu 22.04 for MicroBlaze. | |||||
* | 6/gdb: fix building on FreeBSD 13.1 | Chris Johns | 2023-03-09 | 1 | -0/+4 | |
| | | | | | | See https://sourceware.org/bugzilla/show_bug.cgi?id=30214 Closes #4872 | |||||
* | 6: Update GCC 10 and 12 | Sebastian Huber | 2023-02-24 | 2 | -4/+4 | |
* | 6/7: Update Newlib | Sebastian Huber | 2023-02-24 | 4 | -8/+8 | |
* | Update to binutils 2.40 for rtems 6 | Joel Sherrill | 2023-02-22 | 2 | -1/+14 | |
* | Update to gdb 13.1 for rtems 6 | Joel Sherrill | 2023-02-22 | 2 | -1/+14 | |
* | config/tools/rtems-tools-6.cfg: Include fix for RISC-V BSP set in ↵ | Joel Sherrill | 2023-02-20 | 1 | -2/+2 | |
| | | | | rtems-bsp-builder | |||||
* | Update gdb to 12.1 including patch for hosts with readline 8.2 | Joel Sherrill | 2023-02-16 | 2 | -1/+16 | |
| | | | | | | Issue for hosts with readline 8.2 also exists with gdb 12.1. Closes #4859. | |||||
* | rtems-gdb-11.2.cfg: Add patch for hosts with readline 8.2 | Joel Sherrill | 2023-02-16 | 1 | -0/+3 | |
| | | | | | | | Get the fix from gdb git repo to fix build issue which showed up on Cygwin but was cross platform. Closes #4858. | |||||
* | Revert github tarball hash changes | Kinsey Moore | 2023-02-01 | 8 | -11/+11 | |
| | | | | | GitHub has reverted the change that caused all these tarball hashes to change and so we follow suit. | |||||
* | Update hashes for github-sourced tarballs | Kinsey Moore | 2023-01-30 | 9 | -12/+12 | |
| | | | | | | | Github has changed the way it generates on-the-fly tarball requests which has changed the hashes of the resulting tarballs. This adjusts the affected tarball hashes as a stop-gap until a more permanent solution can be devised. | |||||
* | rtems-tools-6.cfg: Bring in rtems-syms TLS fix | Kinsey Moore | 2023-01-30 | 1 | -2/+2 | |
| | | | | | Update the rtems-tools hash to include the fix for rtems-syms that enables application-hosted TLS variables in loadable modules. | |||||
* | tools: Fix thread names in rtems-record-lttng | Sebastian Huber | 2022-12-02 | 1 | -2/+2 | |
* | 7: Update Binutils, GDB, and GCC | Sebastian Huber | 2022-11-21 | 3 | -6/+6 | |
* | 6: Update GCC 10 and 12 | Sebastian Huber | 2022-11-21 | 2 | -4/+4 | |
* | 6/7: Update Newlib | Sebastian Huber | 2022-11-21 | 4 | -8/+8 | |
* | 7: Update Binutils, GDB, and GCC | Sebastian Huber | 2022-11-10 | 3 | -6/+6 | |
* | 6: Update GCC 10 and 12 | Sebastian Huber | 2022-11-10 | 2 | -4/+4 | |
* | 6/7: Update Newlib | Sebastian Huber | 2022-11-10 | 4 | -8/+8 | |
* | 7: Update Binutils, GDB, and GCC | Sebastian Huber | 2022-11-04 | 3 | -6/+6 | |
* | 6: Update GCC 10 and 12 | Sebastian Huber | 2022-11-04 | 2 | -4/+4 | |
* | 6/7: Update Newlib | Sebastian Huber | 2022-11-04 | 4 | -8/+8 | |
* | Update mipstx39 gdb version to pick up fix to make simulator work | Joel Sherrill | 2022-10-27 | 2 | -3/+3 | |
| | | | | Closes #4689. | |||||
* | 7: Update Binutils, GDB, and GCC | Sebastian Huber | 2022-10-15 | 3 | -6/+9 | |
| | | | | Close #4741. | |||||
* | 6: Update GCC 10 and 12 | Sebastian Huber | 2022-10-14 | 2 | -4/+6 | |
| | | | | Update #4741. | |||||
* | 6/7: Update Newlib | Sebastian Huber | 2022-10-14 | 4 | -8/+11 | |
* | rtems-tools-6.cfg: Bump tools hash | Ryan Long | 2022-10-13 | 1 | -2/+2 | |
* | rtems-gcc-12-newlib-head.cfg: Bump newlib hash to get extern C on resource.h | Joel Sherrill | 2022-09-26 | 1 | -2/+3 | |
* | 6: Update GCC 10 and 12 | Sebastian Huber | 2022-09-24 | 2 | -4/+4 | |
* | 6/7: Update Newlib | Sebastian Huber | 2022-09-24 | 4 | -8/+8 | |
| | | | | This fixes a setjmp() and longjmp() issue for the 64-bit powerpc target. | |||||
* | rtems-tools-6.cfg: Correct hash | Joel Sherrill | 2022-09-21 | 1 | -1/+1 | |
* | rtems-tools-6.cfg: Bump hash to avoid stray comma in aarch64.ini ↵ | Joel Sherrill | 2022-09-21 | 1 | -1/+1 | |
| | | | | configuration for bsp-builder | |||||
* | rtems/kernel: Update to the latest | Chris Johns | 2022-09-21 | 1 | -2/+2 | |
| | | | | - Addition of the Polarfire Icicle BSP | |||||
* | rtems-tools-6.cfg: Bump hash to update BSP list | Joel Sherrill | 2022-09-19 | 1 | -2/+2 | |
* | testproc/gsed: Do not use %include with internal builds | Chris Johns | 2022-09-16 | 1 | -1/+2 | |
* | devel/gcc: Check and build GNU sed if not available on build host | Chris Johns | 2022-09-14 | 1 | -0/+5 | |
| | | | | Closes #2300 | |||||
* | rtems/jpeg: Update the checksum | Chris Johns | 2022-09-09 | 1 | -2/+2 | |
* | rtems/bsps: Update the buildset defines to be arch/bsp | Chris Johns | 2022-09-09 | 14 | -42/+14 | |
| | | | | - Remove the unused defines | |||||
* | rtems/packages: Remove lwip from the generic packages | Chris Johns | 2022-09-09 | 1 | -1/+0 | |
| | | | | - Networking stacks are selected at the BSP level | |||||
* | rtems/kernel: Update the confg file support | Chris Johns | 2022-09-09 | 1 | -119/+121 | |
| | | | | | | | | - Check for config file tests and install if enabled - Support buildset BSP options defines if building a single BSP - Remove bootstrap and autotools fragments | |||||
* | rtems/rtems-bsp: Support a kernel configuration file | Chris Johns | 2022-09-09 | 1 | -15/+31 | |
| | | | | - Support a single BSP defined in a kernel config file | |||||
* | rtems/kernel: Support a list of BSPs as arch/bsp | Chris Johns | 2022-09-09 | 1 | -27/+17 | |
