path: root/rtems/config (follow)
* Add recipe for building rtems-net-legacyVijay Kumar Banerjee2021-03-103-0/+94
* 7: Update tool chainSebastian Huber2021-03-093-8/+8
* 6: Update tool chainSebastian Huber2021-03-093-8/+8
* 7: Update tool chainSebastian Huber2021-03-083-8/+8
* 6: Update tool chainSebastian Huber2021-03-083-8/+8
* 7: Update tool chainSebastian Huber2021-03-053-8/+8
* 6: Update tool chainSebastian Huber2021-03-053-8/+8
* 7: Update tool chainSebastian Huber2021-02-053-8/+8
* 6: Update tool chainSebastian Huber2021-02-053-8/+8
* 6: Update tool chainSebastian Huber2021-01-263-8/+8
| | | | Close #3937.
* 7: Update tool chainSebastian Huber2021-01-253-8/+8
* 6: Use release branches for Binutils/GDBSebastian Huber2021-01-226-12/+35
* 6/7: Update unstable RTEMS 6/7 tool chainSebastian Huber2021-01-214-12/+12
* 6/7: Update unstable RTEMS 6/7 tool chainSebastian Huber2021-01-204-12/+12
* 6: Add FPH2 multilib for nios2Sebastian Huber2021-01-171-0/+3
| | | | Update #4215.
* 6/7: Update unstable RTEMS 6/7 tool chainSebastian Huber2021-01-174-8/+8
* 6/7: Update unstable RTEMS 6/7 tool chainSebastian Huber2021-01-144-12/+12
* 6/7: Update unstable RTEMS 6/7 tool chainSebastian Huber2021-01-144-8/+8
* 6/7: Update unstable RTEMS 6/7 tool chainSebastian Huber2021-01-044-8/+8
* 6/7: Update to the latest rtems-toolsSebastian Huber2021-01-041-2/+2
| | | | Update #4202.
* 6/7: Update unstable RTEMS 6/7 tool chainSebastian Huber2020-12-224-8/+8
* 6/7: Update unstable RTEMS 6/7 tool chainSebastian Huber2020-12-214-12/+12
* Add GMP as a prerequisite for GDBSebastian Huber2020-12-212-0/+2
* 6/7: Update to the latest rtems-toolsSebastian Huber2020-12-161-2/+2
* 6/7: Update unstable RTEMS 6/7 tool chainSebastian Huber2020-12-152-8/+8
| | | | | | This update includes a fix for the ARM Cortex-R52 support in Newlib. Update #4198.
* 6/7: Add multilib for ARM Cortex-R52 processorSebastian Huber2020-12-032-4/+4
| | | | Close #4198.
* 6: Add support for gcov info sectionSebastian Huber2020-12-021-0/+3
| | | | Update #4196.
* 6/7: Update to the latest rtems-toolsSebastian Huber2020-12-021-2/+2
| | | | Close #4195.
* 6/7: Update unstable RTEMS 6/7 tool chainSebastian Huber2020-12-012-8/+8
| | | | Close #4193.
* 6/7: Update unstable RTEMS 6/7 tool chainSebastian Huber2020-11-024-12/+12
* 6/7: Update unstable RTEMS 6/7 tool chainSebastian Huber2020-10-284-12/+12
* 6/7: Update unstable RTEMS 6/7 tool chainSebastian Huber2020-10-264-12/+12
* 6/7: Update unstable RTEMS 6/7 tool chainSebastian Huber2020-10-125-16/+12
* patch gcc i386 multiarchMichael Davidsaver2020-09-211-0/+4
| | | | | | | | | | | | Add patch to change from mtune to march when building multilibs. The mtune argument tunes or optimizes for a specific CPU model but does not ensure the generated code is appropriate for the CPU model. Prior to this patch, i386 compatible code was always generated but tuned for later models. This is the same fix as #2830 but applying to gcc 10. Updates #4084.
* 6/7: Update unstable RTEMS 6/7 tool chainSebastian Huber2020-09-184-12/+12
* 6: Update to the latest rtems-toolsSebastian Huber2020-09-181-3/+2
* Add sis to RISC-V buildJiri Gaisler2020-09-101-0/+1
* rtems: Update to the latest rtems-toolsChris Johns2020-09-071-2/+3
* 6/7: Update unstable RTEMS 6/7 tool chainSebastian Huber2020-09-044-12/+12
* 6/7: Update unstable RTEMS 6/7 tool chainSebastian Huber2020-08-314-12/+12
* Move 5 build sets to 6Chris Johns2020-08-1359-423/+115
| | | | | | | | | | - Move 5/bsps/* to bsps/* - Update package build references from 5 to 6 - Remove 5 build sets. Update #4048
* 6/7: Update unstable RTEMS 6/7 tool chainSebastian Huber2020-07-294-12/+12
* rtems-tools: Pick up fix for modern llvm.Christian Mauderer2020-07-231-2/+2
* 6/7: Remove support for epiphany targetSebastian Huber2020-07-053-19/+0
| | | | Update #3941.
* 6/7: Update unstable RTEMS 6/7 tool chainSebastian Huber2020-07-034-12/+12
* moxie: Update to dtc 1.6.0Sebastian Huber2020-07-013-3/+3
| | | | This fixes the build with a GCC 10 host compiler.
* 6/7: Use RTEMS 6 toolsSebastian Huber2020-06-304-3/+46
* Make comment version independentSebastian Huber2020-06-301-1/+1
* 7: Add unstable RTEMS 7 tool chainSebastian Huber2020-06-2921-0/+114
