* | 5/rtems-libbsd: Update 5-freebsd-12 | Christian Mauderer | 2020-04-17 | 1 | -2/+2 | |
* | 6: Update unstable RTEMS 6 tool chain | Sebastian Huber | 2020-04-17 | 3 | -8/+8 | |
* | 5/rtems-libbsd: Update 5-freebsd-12 | Christian Mauderer | 2020-04-16 | 1 | -2/+2 | |
* | 5/rtems: Update kernel and libbsd. | Christian Mauderer | 2020-04-15 | 2 | -4/+4 | |
* | 6: Update unstable RTEMS 6 tool chain | Sebastian Huber | 2020-04-08 | 1 | -2/+2 | |
| | | | | Update #3937. | |||||
* | 6: Update unstable RTEMS 6 tool chain | Sebastian Huber | 2020-04-07 | 1 | -0/+3 | |
* | rtems: bump rtems-5-kernel | Gedare Bloom | 2020-04-06 | 1 | -2/+2 | |
* | rtems/libbsd: Update to origin/5-freebsd12 HEAD. | Chris Johns | 2020-04-06 | 1 | -4/+4 | |
* | rtems/kernel: Update to origin/master HEAD. | Chris Johns | 2020-04-06 | 1 | -2/+2 | |
* | 6: Update unstable RTEMS 6 tool chain | Sebastian Huber | 2020-04-06 | 3 | -8/+8 | |
* | databases/sqlite: Update to 3.31.1 | Jonathan Brandmeyer | 2020-04-02 | 3 | -28/+24 | |
| | | | | closes #3927. | |||||
* | rtems/libbsd: Update to the latest 5-freebsd12 branch head. | Chris Johns | 2020-03-30 | 1 | -2/+2 | |
* | rtems/kernel: Update to the latest master. | Chris Johns | 2020-03-30 | 1 | -2/+2 | |
* | 5/rtems-tools: Update to pick up rtems-test fixes for GDB | Chris Johns | 2020-03-30 | 1 | -2/+2 | |
* | 5: Update rtems-tools | Sebastian Huber | 2020-03-23 | 1 | -2/+2 | |
| | | | | | | Pick up new features for rtems-record-lttng. Update #3904. | |||||
* | 6: Update unstable RTEMS 6 tool chain | Sebastian Huber | 2020-03-23 | 3 | -8/+8 | |
* | 6: Update unstable RTEMS 6 tool chain | Sebastian Huber | 2020-03-17 | 3 | -10/+10 | |
* | 5: Update Newlib | Sebastian Huber | 2020-03-17 | 7 | -5/+75 | |
| | | | | Pick up fix for crt0.c. | |||||
* | Update gcc to 9.3.0 for targets using 9.2.0 | Joel Sherrill | 2020-03-12 | 4 | -3/+31 | |
* | Update newlib to c56f53a | Joel Sherrill | 2020-03-12 | 7 | -5/+75 | |
| | | | | This is primarily to pick up the bug fix to have i386 fenv methods. | |||||
* | Bump rtems-tools to get mkimage.py into the bin/ directory. | Amar Takhar | 2020-03-08 | 1 | -2/+2 | |
* | rtems/libbsd: Bump libbsd to pick up the libdebugger library check | Chris Johns | 2020-03-05 | 1 | -2/+2 | |
* | rtems/bsps: Add the sparc/erc32 and i386/pc BSP build sets | Chris Johns | 2020-03-05 | 2 | -0/+42 | |
* | 5/bsps: Add some BSPs | Sebastian Huber | 2020-03-05 | 7 | -0/+66 | |
* | 5: Update rtems-tools | Sebastian Huber | 2020-03-05 | 1 | -2/+2 | |
| | | | | Pick up fixes for Debian on sparc64. | |||||
* | Bump RSB to the latest rtems-tools to get mkimage.py | Amar Takhar | 2020-03-04 | 1 | -2/+2 | |
* | 5/rtems-kernel: Update to the head of master to sync with libbsd | Chris Johns | 2020-03-03 | 1 | -2/+2 | |
* | rtems/bsps: Fix building 3rd party packages with various options | Chris Johns | 2020-03-03 | 1 | -15/+38 | |
| | | | | | | | | | | | | | | | | - Fix locating valid tools and BSP. If either is found in the staging area use that else use the specific --with-* option and if not present use the --prefix. - Locate the tools by checking if the arch's C compiler is a valid file. No other checks are made on the tools. - Locate a BSB by checking for a valid pkgconfig file for the BSP. - Only filter flags if the BSP is in the staging area Closes #3893 | |||||
* | 5/rtems-kernel: Update to the head of master to sync with libbsd | Chris Johns | 2020-03-02 | 1 | -2/+2 | |
* | rtems/5 bsets: Update to newlib fbaa096 | Joel Sherrill | 2020-02-28 | 7 | -5/+75 | |
| | | | | | This picks up fixes for at least the RTEMS reported issues for missing extern C in devctl.h and the symlink issue with bsdtar. | |||||
* | 5/rtems-libbsd: Update 5-freebsd-12 | Chris Johns | 2020-02-29 | 1 | -2/+2 | |
* | 5/rtems-libbsd: Switch to the 5-freebsd-12 branch | Chris Johns | 2020-02-28 | 1 | -4/+4 | |
| | | | | This is the RTEMS 5 release branch for libbsd | |||||
* | rtems-libbsd: Do not handle rtems_waf source when released. | Chris Johns | 2020-02-28 | 1 | -7/+12 | |
| | | | | The release libbsd tar file contains the rtems_waf submodule. | |||||
* | 5: Update rtems-tools | Sebastian Huber | 2020-02-26 | 1 | -2/+2 | |
| | | | | | | Pick up update to waf-2.0.19. Update #3569. | |||||
* | rtems/5: Update to gdb-9.1 | Chris Johns | 2020-02-12 | 2 | -1/+13 | |
| | | | | - This version fixes build issues on Windows (MinGW64) | |||||
* | 5: Update to Binutils 2.34 | Sebastian Huber | 2020-02-09 | 6 | -5/+32 | |
* | 6: Update unstable RTEMS 6 tool chain | Sebastian Huber | 2020-02-04 | 1 | -1/+1 | |
| | | | | Shorten the commit hash to be in line what the server returns. | |||||
* | 6: Update unstable RTEMS 6 tool chain | Sebastian Huber | 2020-02-04 | 1 | -4/+4 | |
| | | | | | | | | Use official GCC Git repository. Includes a fix for: https://gcc.gnu.org/bugzilla/show_bug.cgi?id=93543 | |||||
* | 6: Update unstable RTEMS 6 tool chain | Sebastian Huber | 2020-02-04 | 3 | -8/+8 | |
* | 5: Update rtems-tools | Sebastian Huber | 2020-01-08 | 1 | -2/+2 | |
* | 6: Update unstable RTEMS 6 tool chain | Sebastian Huber | 2020-01-02 | 3 | -8/+8 | |
* | 6: Update unstable RTEMS 6 tool chain | Sebastian Huber | 2019-12-20 | 3 | -8/+8 | |
* | 5: Update rtems-tools | Sebastian Huber | 2019-12-19 | 1 | -2/+2 | |
| | | | | Update #3413. | |||||
* | 5/rtems-epiphany.bset: Rework to have meaningful name for gdb | Joel Sherrill | 2019-12-12 | 1 | -3/+3 | |
| | | | | closes #3809. | |||||
* | rtems: Set the RTEMS release message's RSB version correctly | Chris Johns | 2019-12-13 | 1 | -1/+1 | |
| | | | | Closes #3842 | |||||
* | 6: Use external SIS instead of GDB simulator | Sebastian Huber | 2019-12-05 | 1 | -0/+2 | |
* | 6: Update unstable RTEMS 6 tool chain | Sebastian Huber | 2019-12-04 | 3 | -8/+8 | |
* | 5: Update rtems-tools | Sebastian Huber | 2019-12-02 | 1 | -2/+2 | |
| | | | | Pick up bin2c improvements. | |||||
* | 5: Update the hash for the new rtems-tools revision | Hesham Almatary | 2019-11-29 | 1 | -1/+1 | |
| | | | | Fixes #3827 | |||||
* | 5: Update rtems-tools | Hesham Almatary | 2019-11-29 | 1 | -1/+1 | |
| | | | | Fixes #3827 |
