* | rtems: Update the kernel and tools packages to the latest RTEMS 5 | Chris Johns | 2020-05-07 | 1 | -2/+2 |
* | 5/rtems-tools: Update to pick up rtems-test fixes for GDB | Chris Johns | 2020-03-30 | 1 | -2/+2 |
* | 5: Update rtems-tools | Sebastian Huber | 2020-03-23 | 1 | -2/+2 |
| | | | | | | Pick up new features for rtems-record-lttng. Update #3904. | ||||
* | Bump rtems-tools to get mkimage.py into the bin/ directory. | Amar Takhar | 2020-03-08 | 1 | -2/+2 |
* | 5: Update rtems-tools | Sebastian Huber | 2020-03-05 | 1 | -2/+2 |
| | | | | Pick up fixes for Debian on sparc64. | ||||
* | Bump RSB to the latest rtems-tools to get mkimage.py | Amar Takhar | 2020-03-04 | 1 | -2/+2 |
* | 5: Update rtems-tools | Sebastian Huber | 2020-02-26 | 1 | -2/+2 |
| | | | | | | Pick up update to waf-2.0.19. Update #3569. | ||||
* | 5: Update rtems-tools | Sebastian Huber | 2020-01-08 | 1 | -2/+2 |
* | 5: Update rtems-tools | Sebastian Huber | 2019-12-19 | 1 | -2/+2 |
| | | | | Update #3413. | ||||
* | 5: Update rtems-tools | Sebastian Huber | 2019-12-02 | 1 | -2/+2 |
| | | | | Pick up bin2c improvements. | ||||
* | 5: Update the hash for the new rtems-tools revision | Hesham Almatary | 2019-11-29 | 1 | -1/+1 |
| | | | | Fixes #3827 | ||||
* | 5: Update rtems-tools | Hesham Almatary | 2019-11-29 | 1 | -1/+1 |
| | | | | Fixes #3827 | ||||
* | rtems: Fix kernel and tools release source package selection. | Chris Johns | 2019-11-18 | 1 | -3/+8 |
| | | | | Closes #3814 | ||||
* | 5: Update RTEMS tools | Sebastian Huber | 2019-09-10 | 1 | -2/+2 |
| | | | | Fix rtems-record-lttng issue on macOS. | ||||
| | | | | | | Fix rtems-record-lttng issues on Windows. Close ##3793. | ||||
* | 5/tools: Update to the head of master | Chris Johns | 2019-08-27 | 1 | -2/+2 |
* | 5/rtems-tools: Update RTEMS tools. | Chris Johns | 2019-06-25 | 1 | -2/+2 |
* | 5/rtems-tools: Update RTEMS tools. | Chris Johns | 2019-06-12 | 1 | -3/+2 |
* | 5/rtems-tools: Update RTEMS tools | Chris Johns | 2019-05-05 | 1 | -2/+2 |
* | gdb: add RISC-V and code coverage support to sis | Jiri Gaisler | 2019-01-29 | 1 | -2/+2 |
* | 5/rtems-tools: Update RTEMS tools | Christian Mauderer | 2018-12-21 | 1 | -2/+2 |
| | | | | | | | Picks up the new waf in rtems-tools to be compatible with python 3.7 and some tester updates. Update #3569. | ||||
* | 5/rtems-tools: Bump the version to pick up the Windows fixes. | Chris Johns | 2018-11-29 | 1 | -2/+2 |
* | tools-5-1.cfg: Bump to latest | Chris Johns | 2018-11-17 | 1 | -2/+2 |
| | | | | | - Fix efltools on ARM 64bit - Fixes to converage | ||||
* | 5: Update RTEMS tools | Sebastian Huber | 2018-11-14 | 1 | -2/+2 |
| | | | | | | Pick up m32c removal. Update #3599. | ||||
* | rtems-tools-5-1.cfg: Bump to latest | Joel Sherrill | 2018-10-14 | 1 | -2/+3 |
| | | | | closes #3401, #3402, #3424. | ||||
* | 5: Update tools for RISC-V BSP builder support | Sebastian Huber | 2018-08-07 | 1 | -2/+2 |
| | | | | Update #3433. | ||||
* | 5: Update tools to not build obsolete BSP variants | Sebastian Huber | 2018-07-03 | 1 | -2/+2 |
| | | | | Update #3459. | ||||
* | 5: Update tools to fix rtems-test coverage support. | Chris Johns | 2018-06-20 | 1 | -2/+2 |
* | 5: Update tools for CXC x86_64-w32-mingw32 support | Sebastian Huber | 2018-06-19 | 1 | -2/+2 |
| | | | | Close #3461. | ||||
* | 5: Update tools to ship rtems-bin2c | Sebastian Huber | 2018-06-15 | 1 | -2/+2 |
| | | | | Update #3380. | ||||
* | rtems-tools: Update to pick up the --enable-rtems-debug fix. | Chris Johns | 2018-04-24 | 1 | -2/+2 |
* | 5: Use a specific RTEMS tools version | Sebastian Huber | 2018-04-18 | 1 | -2/+26 |
| | | | | | | Download via cgit archive. Close #3403. | ||||
* | Change RTEMS version from 4.12 to 5 | Sebastian Huber | 2017-11-09 | 1 | -0/+15 |
Update #3220. |
