* | Fix 4.10 and 4.9 building. | rtems | 2016-03-01 | 1 | -0/+1 |
| | | | | | | Add the 4.9 newlib 1.16.0-20090324 patch. Add a release to the 4.9 RTEMS kernel. Add a release to the 4.10 RTEMS kernel. | ||||
* | Support released downloading of the RTEMS Tools and RTEMS Kernel. | Chris Johns | 2015-12-11 | 1 | -7/+2 |
| | | | | Add a --without-error-reports flags to reduce the noise on --with-downloading. | ||||
* | rtems-4.10: Add checksums. | Chris Johns | 2014-08-13 | 1 | -1/+4 |
* | fix the problems for the set build of 4.9 and 4.10 1. "expat-2.1.0-1 file ↵ | Yin Yan | 2013-05-22 | 1 | -0/+5 |
| | | | | | | not found 2. "%{var} not fount" I only tested them for 4.9/rtrms-sparc, not sure for rest of them. | ||||
* | Add support for RTEMS 4.10. | Chris Johns | 2013-03-20 | 1 | -0/+13 |
This change adds support for RTEMS 4.10 tools plus builds the latest RTEMS 4.10.2 release. |
