Close #3292
Also add:
--with-rtemsbsp="bsp,bsp,bsp"
--with-rtems-smp
--with-rtems-tests
--with-rtems-tests=sample
--with-rtems-tests=all
Closes #2526.
Provide without_release_url support in the configuration file so
the release tarball download of the kernel and tools uses the
release's top level directory and not the sources directory.
Closes #2481.
Add a --without-error-reports flags to reduce the noise on --with-downloading.
Reported by Marco Hoefle <marco.hoefle@nanotronic.ch>.
Remove the numbered source and patches and automatically manage
sources and patches. This removes the overhead in maintaining large
collections of patches.
Fix shell tests where '==' was used rather than '='.
This changes adds support to build the autotools if the host installed
version is not a suitable version. Autoconf and automake have hard coded
references to the install prefix and host tools and this makes it impossible
to relocate, that is use in any path other than the install prefix. To
bootstrap automake you need to first build a suitable autoconf and with that
you can built automake for the install prefix. The other complication is
not referencing the install prefix in the path when building in the RSB.
Having the install prefix in the path can result in strange issues appearing
such as gcc using a new assembler feature not present in an older assember
installed under the install prefix.
The process is to build the autotools using an install prefix to an
internal path inside the RSB temporary path and to use that autoconf
to build the version for the install prefix. The internal install
prefix version is also used to bootstrap RTEMS.
This change adds support for RTEMS 4.10 tools plus builds the latest
RTEMS 4.10.2 release.
