path: root/rtems/config/tools/rtems-gdb-7.8.1-1.cfg (follow)
* 5: Avoid rtems-tools for epiphany GDBSebastian Huber2017-11-101-2/+2
| | | | Close #3226.
* 4.12: Update all MD5 hashes to SHA256.Chris Johns2017-10-121-3/+3
| | | | Closes #2536.
* Update all 4.11 archs to newlib-2.2.0-1 and gdb-7.8.2 where possible.Chris Johns2015-02-071-2/+2
| | | | | Remove the extra gdb-7.8.1.cfg and added support to allow GDB tar compression to be version defined. GDB has changed it default to .xz.
* sparc-gdb: use patch for leon2/3 support to sisJiri Gaisler2014-12-011-0/+28
Also fixes the can't compute CFA problem.
