Closes #3202.
Closes #2536.
Updates #2644.
Remove the extra gdb-7.8.1.cfg and added support to allow GDB tar
compression to be version defined. GDB has changed it default to .xz.
File download by http, ftp, pw support checksum. The %hash
directive provides a means of setting a hash used to
checksum the file.
Files on disk or just downloaded are checked.
Remove the numbered source and patches and automatically manage
sources and patches. This removes the overhead in maintaining large
collections of patches.
Update lm32, m32c, m32r, m68k, microblaze, mips, powerpc, sh, sparc64
v850.
GDB did not build out of the box on FreeBSD 10.0 due to the iconv move
to libc effecting the gettext port with Python. The patch provided is
from the gdb port (devel/gdb) and add the LDFLAGS to the link command line
when Python is used and this adds /usr/local/lib if needed.
Note, some architectures remain broken with the new gcc.
All patches are now downloaded. No patches or source is held
in the RTEMS Source Builder repo.
As part of this the build sets now have a single rtems_arch define
and the base RTEMS 4.11 build set now creates the _target macro.
With this change a method to manage RTEMS specific patches has been
put in place where build sets can define patches. This avoids needing
special configuration files.
The MIPS STX39 is a special build for the simulator and the Moxie
build has a specific patch which was in the common configuration.
Binutils and the compiler build how-ever gdb needs a tool called 'dtc'
to build the simulator. This is not present on my FreeBSD test box.
Add arch build files. This allows archs to have different versions
and patches for specific tools.
Break the RTEMS config directory up into separate directories to
make long term maintenance easier. This required a change to config.py
to handle the config files being in subdirs of the config directory.
The defaults have been updated to include the install SB root so
packages built before a package are available.
Add makeinfo to the required tools. GDB (and others) need it to
build without error.
