2024-03-14 | rtems-gcc-*-newlib-head.cfg: Bump hash for newlib | Joel Sherrill | 1 | -2/+2 | |
This was driven by the increase in fdset size from 64 to 256 files. | |||||
2023-11-22 | 7: Update Binutils, GDB, and GCC | Sebastian Huber | 1 | -2/+2 | |
Keep RTEMS up to date with the upstream development. | |||||
2023-11-22 | 6/7: Update Newlib | Sebastian Huber | 1 | -2/+2 | |
Pick up fixes for ARM/optimized-routines and the memory reclamation at thread exit. Update #4510. Update #4967. | |||||
2023-10-18 | 7: Update Binutils, GDB, and GCC | Sebastian Huber | 1 | -2/+2 | |
2023-10-12 | 6/7: Update Newlib | Sebastian Huber | 1 | -5/+2 | |
Pick up latest changes from ARM/optimized-routines. Close 4510. | |||||
2023-07-20 | 7: Update Binutils, GDB, and GCC | Sebastian Huber | 1 | -2/+2 | |
2023-07-20 | 6/7: Update Newlib | Sebastian Huber | 1 | -2/+2 | |
2023-06-30 | 7: Update Binutils, GDB, and GCC | Sebastian Huber | 1 | -2/+2 | |
2023-06-30 | 6/7: Update Newlib | Sebastian Huber | 1 | -2/+2 | |
2023-05-19 | rtems-gcc-*-newlib-head.cfg: Update to include true long double math | Joel Sherrill | 1 | -2/+2 | |
Previously newlib only had long double math functions when the sizeof(double) was equal to sizeof(long double). Newlib now includes support for true long double on x86, x86_64, and aarch64. These files were not included in the previous commit. | |||||
2023-04-25 | 7: Update Binutils, GDB, and GCC | Sebastian Huber | 1 | -2/+2 | |
2023-04-25 | 6/7: Update Newlib | Sebastian Huber | 1 | -2/+2 | |
2023-04-21 | 6/7: Update Newlib | Sebastian Huber | 1 | -2/+2 | |
2023-02-24 | 6/7: Update Newlib | Sebastian Huber | 1 | -2/+2 | |
2023-02-01 | Revert github tarball hash changes | Kinsey Moore | 1 | -2/+2 | |
GitHub has reverted the change that caused all these tarball hashes to change and so we follow suit. | |||||
2023-01-30 | Update hashes for github-sourced tarballs | Kinsey Moore | 1 | -2/+2 | |
Github has changed the way it generates on-the-fly tarball requests which has changed the hashes of the resulting tarballs. This adjusts the affected tarball hashes as a stop-gap until a more permanent solution can be devised. | |||||
2022-11-21 | 7: Update Binutils, GDB, and GCC | Sebastian Huber | 1 | -2/+2 | |
2022-11-21 | 6/7: Update Newlib | Sebastian Huber | 1 | -2/+2 | |
2022-11-10 | 7: Update Binutils, GDB, and GCC | Sebastian Huber | 1 | -2/+2 | |
2022-11-10 | 6/7: Update Newlib | Sebastian Huber | 1 | -2/+2 | |
2022-11-04 | 7: Update Binutils, GDB, and GCC | Sebastian Huber | 1 | -2/+2 | |
2022-11-04 | 6/7: Update Newlib | Sebastian Huber | 1 | -2/+2 | |
2022-10-15 | 7: Update Binutils, GDB, and GCC | Sebastian Huber | 1 | -2/+3 | |
Close #4741. | |||||
2022-10-14 | 6/7: Update Newlib | Sebastian Huber | 1 | -2/+3 | |
2022-09-24 | 6/7: Update Newlib | Sebastian Huber | 1 | -2/+2 | |
This fixes a setjmp() and longjmp() issue for the 64-bit powerpc target. | |||||
2022-09-08 | 7: Update Binutils, GDB, and GCC | Sebastian Huber | 1 | -2/+2 | |
2022-09-08 | 6/7: Update Newlib | Sebastian Huber | 1 | -2/+2 | |
2022-07-21 | 6/7: Update Newlib | Sebastian Huber | 1 | -2/+2 | |
This makes the --enable-newlib-reent-thread-local (_REENT_THREAD_LOCAL_STORAGE) Newlib configuration option available. Update #4560. | |||||
2022-07-01 | 7: Update Binutils, GDB, and GCC | Sebastian Huber | 1 | -2/+2 | |
2022-07-01 | 6/7: Update Newlib | Sebastian Huber | 1 | -2/+2 | |
This Newlib update fixes a FreeBSD kernel space issue with <sys/cpuset.h>. Update #4667. | |||||
2022-06-24 | 6/7: Update Newlib | Sebastian Huber | 1 | -2/+2 | |
This Newlib update fixes a namespace pollution issue with <sys/bitset.h>. Close #4667. | |||||
2022-05-09 | 7: Remove superfluous GCC patch | Sebastian Huber | 1 | -3/+0 | |
2022-05-09 | 7: Update Binutils, GDB, and GCC | Sebastian Huber | 1 | -2/+2 | |
2022-05-04 | 7: Back port gcov-tool merge-stream to GCC 12 | Sebastian Huber | 1 | -0/+3 | |
Update #4196. | |||||
2022-05-04 | 7: Update Binutils, GDB, and GCC | Sebastian Huber | 1 | -2/+2 | |
2022-04-27 | 7: Update Binutils, GDB, and GCC | Sebastian Huber | 1 | -2/+2 | |
2022-04-22 | 6/7: Update GCC prerequisites for GCC 10 and 12 | Sebastian Huber | 1 | -1/+1 | |
2022-03-22 | 7: Update Binutils, GCC, and GDB | Sebastian Huber | 1 | -2/+2 | |
2022-03-22 | 6/7: Update Newlib | Sebastian Huber | 1 | -2/+2 | |
Fix the iconv support to avoid linker errors like this: newlib/libc/iconv/lib/ucsconv.c:66: undefined reference to `_iconv_to_ucs_ces' | |||||
2022-03-18 | 6/7: Update Newlib | Sebastian Huber | 1 | -2/+2 | |
The update of the Newlib build system seems to be finished. | |||||
2022-03-18 | 6/7: Update AArch64 newlib patch | Kinsey Moore | 1 | -2/+2 | |
The existing patch fails to build with the latest newlib. This picks up an updated patch that compiles with both older and newer newlib. | |||||
2022-03-09 | 6/7: Update Newlib | Sebastian Huber | 1 | -2/+2 | |
This fixes an issue for some awk versions. | |||||
2022-02-26 | 7: Update Binutils, GDB, and GCC | Sebastian Huber | 1 | -2/+2 | |
2022-02-26 | 6/7: Update Newlib | Sebastian Huber | 1 | -2/+2 | |
2022-01-11 | Update Newlib for powerpc/setjmp improvements | Sebastian Huber | 1 | -2/+2 | |
2021-10-07 | Update newlib to fetch <sys/tree.h> optimizations | Sebastian Huber | 1 | -2/+2 | |
Close #4522. | |||||
2021-09-20 | rtems-gcc-head-newlib-head.cfg: Add newlib patch | Ryan Long | 1 | -0/+3 | |
Adds patch to add sanitation to the padding of bits and size_t types for AArch64 tools builds with newlib. These changes have been made in ARM, but newlib has yet to pull them. This can be removed once newlib has pulled the code. Updates #4510 | |||||
2021-09-02 | Update newlib to 9069cb9 hash | Joel Sherrill | 1 | -2/+2 | |
This update is to include a fix for building rtems-libbsd using the previous newlib hash. <sys/signal.h> was using a macro specific to the newlib implementation of <stdint.h>. When building rtems-libbsd, -ffreestanding is used and that switches to the gcc <stdint.h> and there was a compilation error. | |||||
2021-05-21 | Bump newlib for rtems 6 and 7 to get UTIME_NOW and UTIME_OMIT constants. | Joel Sherrill | 1 | -2/+2 | |
