This picks up fixes for at least the RTEMS reported issues for missing
extern C in devctl.h and the symlink issue with bsdtar.
Pick up scandir() fixes.
Pick up <sys/time.h> updates from FreeBSD.
Update #3472.
Update #3384.
Fix v850 target issue related to the new -fdata-sections build.
Remove <machine/param.h> include from <sys/_cpuset.h>.
Close #3577.
Fix posix_memalign() attributes.
Use -fdata-sections and -ffunction-sections to build Newlib.
Pick up POSIX header file changes and improved opendir() implementation.
This addesses time of check and time of use error conditions (TOCTOU).
Update #3530.
Update #3545.
Update #3546.
Update #3547.
Pick up POSIX header file changes for an upcomming FreeBSD baseline
update in libbsd.
Update #3472.
Close #3491.
It includes a fix for bug in the ctype support, some FreeBSD
compatibility changes in <sys/cdefs.h> for libbsd and a new
configuration option for all targets newlib/configure.host which is used
by the RISC-V port.
Close #3452.
Update RISC-V GCC to a GCC 9 branch commit.
Close #3342.
Close #3343.
Update #3452.
