2017-12-19 | 5: Update SPARC chip errata workarounds | Sebastian Huber | 1 | -2/+2 | |
Update #3242. | |||||
2017-12-04 | 5: Ada: Fix more POSIX types | Sebastian Huber | 1 | -2/+2 | |
Update #3256. | |||||
2017-12-01 | 5: Ada: Fix some POSIX types | Sebastian Huber | 1 | -0/+3 | |
Close #3256. | |||||
2017-11-30 | 5: Add SPARC chip errata workarounds | Sebastian Huber | 1 | -0/+3 | |
Close #3242. | |||||
2017-11-09 | 5: Add Newlib patches | Sebastian Huber | 1 | -0/+6 | |
Update #3185. Close #3189. | |||||
2017-10-05 | 4.12: Update to Newlib 2.5.0.20170922 | Sebastian Huber | 1 | -6/+4 | |
The time_t is now a 64-bit signed integer. This update includes a patch to introduce the self-contained POSIX synchronization objects. Update #2514. Update #3111. Update #3112. Update #3113. Update #3114. Update #3115. Update #3116. | |||||
2017-09-10 | mips: Use the FreeBSD fix for Darwin MIP tools build. | Chris Johns | 1 | -1/+1 | |
Closes 3127. | |||||
2017-08-25 | 4.12: Change clock_t to 64-bit | Sebastian Huber | 1 | -0/+5 | |
Update #2135. Update #3111. | |||||
2017-08-22 | 4.12: Fix 64-bit PowerPC support of GCC 7.2 | Sebastian Huber | 1 | -0/+4 | |
Update #3082. | |||||
2017-08-22 | 4.12: Add basic RISC-V tool chain | Sebastian Huber | 1 | -0/+3 | |
GDB is not included. This probably needs some patches or an update to GDB 8.0. | |||||
2017-08-22 | 4.12: Update to GCC 7.2 | Sebastian Huber | 1 | -0/+28 | |
