path: root/rtems/config/tools/rtems-gcc-4.9.2-newlib-git-1.cfg (follow)
* update newlib git revision to get <sys/select.h> RTEMS dependencyHesham Almatary2016-02-271-1/+1
* 4.11/rtems-epiphany: Use the latest newlib git head.Chris Johns2015-10-261-1/+1
| | | | Move to the latest to pick up the recent newlib changes.
* Bump newlib git headGedare Bloom2015-03-231-1/+1
* newlib has moved to git. The old CVS->git mirror is dead. Update.Joel Sherrill2015-03-191-1/+1
| | | | | | | This moves all git hashes to the head of newlib's git and updates the URL. Use hash: 1c144ed142224cd112c1c9177a4231bef7975f9f
* Switch to newlib-git-1 and bump version for all 4.9.2 toolsGedare Bloom2015-03-051-1/+1
* Update newlib to 20 Nov 2014 and hash de616601501c4f82968683e80c112604a2d40222Joel Sherrill2014-11-201-1/+1
| | | | | | | This picks up at least these RTEMS Project patches: + Joel Sherrill to ensure the PRIxxPTR defines are correct on all targets. + Sebastian Huber NGROUPS adjusted to have even value.
* rtems4.11: Upgrade to gcc-4.9.2. Build rtems-tools and install.Chris Johns2014-10-311-0/+13
RTEMS kernel requires the rtems-tools package be installed to build the libdl tests.
