* | sb: Implement %source and %patch to manage source and patches. | Chris Johns | 2014-05-13 | 1 | -5/+0 |
| | | | | | | Remove the numbered source and patches and automatically manage sources and patches. This removes the overhead in maintaining large collections of patches. | ||||
* | Add missing RTEMS patches to binutils-2.23.1. | Chris Johns | 2013-03-13 | 1 | -0/+5 |
* | Restructure RTEMS Config Files | Chris Johns | 2013-02-13 | 1 | -0/+20 |
Add arch build files. This allows archs to have different versions and patches for specific tools. Break the RTEMS config directory up into separate directories to make long term maintenance easier. This required a change to config.py to handle the config files being in subdirs of the config directory. The defaults have been updated to include the install SB root so packages built before a package are available. Add makeinfo to the required tools. GDB (and others) need it to build without error. |
