Using the RSB release version for the gcc version string means the
tools have a version string that matches the release.
Close #3294
Move the 4.12 version and base defines to just RTEMS base defines
which includes the version. This removes the version from a number of
files and makes it simpler to move to a new version. It however means
we cannot support more than version on master.
This change further breaks 4.10 and 4.9 however it means we can
branch these versions and better support them on their branches.
Adding the host name results in the tar files created by the
--bset-tar-file and --pkg-tar-files to contain the host name.
This is useful when building Cxc packages.
Drop the GCC version since this is already part of the normal GCC
version message. Drop the release number from the RSB since the Git
commit identifies the RSB version uniquely. Use a "Name Version, ..."
pattern.
Remove the 'opt' from various macros and shell variables.
Add pkgconfig to the checks to make it clear the check is a
pkgconfig check.
Add NTP support as the first package to be built using the RSB.
Split the RTEMS URL's out from the base bset file into a separate
file that be included by other files.
Add an RTEMS BSP configuration file to help abstract the process
of building 3rd party packages.
Clean the cross and canadian cross support up so we can cleanly support
cross and canadian cross building.
Refactor the pkgconfig support and clean up the PC file handling of
loading modules.
Add support for %{?..} to return false if a macro is %{nil}.
Add %{pkgconfig ..} support to allow better control of access RTEMS
pkgconfig files.
This fixes patch downloading.
This change adds support for RTEMS 4.10 tools plus builds the latest
RTEMS 4.10.2 release.
All patches are now downloaded. No patches or source is held
in the RTEMS Source Builder repo.
As part of this the build sets now have a single rtems_arch define
and the base RTEMS 4.11 build set now creates the _target macro.
With this change a method to manage RTEMS specific patches has been
put in place where build sets can define patches. This avoids needing
special configuration files.
Add per arch build sets as this is really what RTEMS needs. You
can then vary the version based on the architecture.
Add '%include' to the buildset files.
