* | 5/packages: Add curl and update all packages with RTEMS 5 and LibBSD | Chris Johns | 2019-07-21 | 2 | -0/+41 |
- Update rtems-bsp support to correctly handle hosts for BSP. - Clean up the options for a BSP. - Check all RTEMS 5 packages and add 5/rtems-packages for all that build. - Update download locations and checksum of all packages. - The work requires the kernel and Libbsd hacve the same prefix. |
