* | Move 5 build sets to 6 | Chris Johns | 2020-08-13 | 1 | -5/+0 |
| | | | | | | | | | | - Move 5/bsps/* to bsps/* - Update package build references from 5 to 6 - Remove 5 build sets. Update #4048 | ||||
* | 5/packages: Add curl and update all packages with RTEMS 5 and LibBSD | Chris Johns | 2019-07-21 | 2 | -0/+41 |
- Update rtems-bsp support to correctly handle hosts for BSP. - Clean up the options for a BSP. - Check all RTEMS 5 packages and add 5/rtems-packages for all that build. - Update download locations and checksum of all packages. - The work requires the kernel and Libbsd hacve the same prefix. |
