* | 4.12/rtems-or1k.bset: Use Newlib 2.4.0.20160527 | Hesham Almatary | 2016-06-13 | 1 | -1/+1 |
* | rtems: Refactor to move to a single version on master. | Chris Johns | 2016-04-15 | 1 | -3/+2 |
| | | | | | | | | | | Move the 4.12 version and base defines to just RTEMS base defines which includes the version. This removes the version from a number of files and makes it simpler to move to a new version. It however means we cannot support more than version on master. This change further breaks 4.10 and 4.9 however it means we can branch these versions and better support them on their branches. | ||||
* | 4.12/rtems-or1k.bset: Update newlib to 2.4.0 | Joel Sherrill | 2016-04-13 | 1 | -1/+1 |
* | Bump OpenRISC versions | Stefan Wallentowitz | 2016-03-24 | 1 | -7/+8 |
| | | | | | | | | | | Bump the OpenRISC toolchain to newer versions. * Binutils to 2.26 * GCC to 4.9.3 * GDB to 7.11 updates #2669 | ||||
* | Add RTEMS 4.12 build set | Sebastian Huber | 2015-11-10 | 1 | -0/+43 |
