- Build GDb first as we do for RTEMS 5 and later
- Update GDB to 9.1 for all archs expect SPARC. The SIS patches
only apply to 7.9. Disable Python for SPARC
Closes #4111
Bump the OpenRISC toolchain to newer versions.
* Binutils to 2.26
* GCC to 4.9.3
* GDB to 7.9
updates #2668
Author: Stefan Wallentowitz <stefan.wallentowitz@tum.de>
Date: Thu Feb 12 14:21:42 2015 +0100
Replace binutils for or1k as it is upstream there
RTEMS kernel requires the rtems-tools package be installed to
build the libdl tests.
1- Refer to newlib-cvs as it supports OpenRISC/RTEMS by now.
2- Use gcc.4.8.3 release instead of 4.8.2 one.
3- Refer to the new gcc-4.8.3 patch.
4- Add hash feature for patches.
Refactor some of the configurations to make it easier to maintain.
Add gcc-4.9.x support.
Configuration files get the following releases:
- binutils-2.24
- newlib-2.1.0
- gcc-4.8.2
- gdb-7.7
Patches to tool-chain are mix of OpenRISC original patches and other
additions to build the previous releases for RTEMS.
