* | doc: add example of a local patch | Gedare Bloom | 2016-08-01 | 1 | -3/+9 |
* | doc: source-builder.txt: Update installtion for ubuntu packages | Punit Vara | 2016-08-01 | 1 | -2/+3 |
| | | | | | This patch fixes the most common python missing error for RTEMS tool chain build and RSB built is tested for ubuntu 16.04.1 LTS | ||||
* | doc: correct a typo of RTEMS | Sambeet Panigrahi | 2016-08-01 | 1 | -1/+1 |
* | doc: corrected typo of FreeBSD | Sambeet Panigrahi | 2016-08-01 | 1 | -1/+1 |
* | doc: fix link to patch for CVS | Gedare Bloom | 2015-11-04 | 1 | -1/+1 |
* | doc: zlib1g-dev package needs to be installed on Linux Mint | Hesham Almatary | 2015-08-18 | 1 | -0/+10 |
* | Add MSYS2 documentation. | Chris Johns | 2015-03-12 | 1 | -14/+44 |
* | doc: Update the Fedora package list for Fedora 19. | Chris Johns | 2014-09-05 | 1 | -2/+3 |
* | sb: Add support for the standard git protocols for the %source command. | Chris Johns | 2014-08-29 | 1 | -0/+6 |
| | | | | | | The source selector 'git://' now supports a protocol option that lets you set the specific protocol git is to use to access a remote repository. | ||||
* | doc: Minor corrections and updates. | Chris Johns | 2014-07-30 | 1 | -11/+19 |
* | doc: Add %hash. | Chris Johns | 2014-07-29 | 1 | -2/+44 |
* | doc: Add RTEMS 3rd Party package building instructions. | Chris Johns | 2014-07-28 | 1 | -55/+433 |
* | doc: Use the internal asciidoc tool. | Chris Johns | 2014-05-14 | 1 | -2/+10 |
* | doc: Update the documentation for the new source and patch. | Chris Johns | 2014-05-14 | 1 | -177/+220 |
* | doc: Updated after GSoC student feedback. | Chris Johns | 2014-04-08 | 1 | -10/+28 |
* | source-builder.txt: Correct spelling errors | Joel Sherrill | 2014-03-20 | 1 | -18/+18 |
* | doc: New version and date. | Chris Johns | 2014-03-20 | 1 | -1/+1 |
* | doc: Add patch details. | Chris Johns | 2014-03-20 | 1 | -0/+75 |
* | freebsd: Add support for FreeBSD 10.0. | Chris Johns | 2014-03-20 | 1 | -1/+22 |
| | | | | | | | GDB did not build out of the box on FreeBSD 10.0 due to the iconv move to libc effecting the gettext port with Python. The patch provided is from the gdb port (devel/gdb) and add the LDFLAGS to the link command line when Python is used and this adds /usr/local/lib if needed. | ||||
* | Add notes on building on Maverick. | Chris Johns | 2013-11-10 | 1 | -0/+15 |
* | New Configurations documentation. | Chris Johns | 2013-11-10 | 1 | -1/+333 |
* | Add Fedora 18 dependence. | Chris Johns | 2013-11-05 | 1 | -0/+5 |
* | doc: Add NetBSD. | Chris Johns | 2013-09-10 | 1 | -0/+13 |
* | doc: Add a cross build section. | Chris Johns | 2013-08-31 | 1 | -100/+167 |
* | doc: Improve the section on reporting errors. | Chris Johns | 2013-08-27 | 1 | -6/+17 |
* | doc: Add controlling the build. Add patch to cygwin. | Chris Johns | 2013-08-14 | 1 | -1/+17 |
* | doc: Add the patch module to cygwn. | Chris Johns | 2013-08-14 | 1 | -0/+1 |
* | Add a README for github to show. | Chris Johns | 2013-07-25 | 1 | -9/+9 |
* | Update using the RTEMS path. | Chris Johns | 2013-07-19 | 1 | -2/+11 |
* | Add what is built and how to set the path. | Chris Johns | 2013-07-18 | 1 | -1/+12 |
* | Fix link in documentation | Sebastian Huber | 2013-07-13 | 1 | -1/+1 |
* | Fix formating. | Chris Johns | 2013-06-02 | 1 | -2/+2 |
* | Update doc with file searching details. | Chris Johns | 2013-06-02 | 1 | -1/+4 |
* | Update the git clone URL. | Chris Johns | 2013-05-17 | 1 | -1/+1 |
* | Add mail and personal macros. | Chris Johns | 2013-04-30 | 1 | -15/+82 |
* | Add macro include support. Use it for building from head. | Chris Johns | 2013-04-26 | 1 | -6/+37 |
| | | | | | This change provides a simple way to build all parts of the tools from version control. | ||||
* | Add a tip about using --dry-run before an initial build to check all is ok. | Chris Johns | 2013-04-25 | 1 | -1/+7 |
* | Fix the autotools prefix in the RTEMS example. | Chris Johns | 2013-04-23 | 1 | -1/+1 |
* | Update the RTEMS Configurations to show how to build autotools if they are ↵ | Chris Johns | 2013-04-23 | 1 | -4/+37 |
| | | | | not valid. | ||||
* | Add source and patches section. | Chris Johns | 2013-04-21 | 1 | -3/+103 |
* | Add the --regression option. | Chris Johns | 2013-04-16 | 1 | -0/+6 |
* | Add --no-download to disable the downloader. | Chris Johns | 2013-04-15 | 1 | -3/+9 |
* | Document fixes reported by users. | Chris Johns | 2013-04-14 | 1 | -34/+50 |
* | Updated documentation. | Chris Johns | 2013-04-14 | 3 | -113/+342 |
* | Add Windows support doco. Add the host build table. | Chris Johns | 2013-04-01 | 2 | -18/+157 |
* | Add which type of hosts work. Some 32bit hosts have issues. | Chris Johns | 2013-03-31 | 1 | -6/+6 |
* | Add openSUSE and rearrange them. | Chris Johns | 2013-03-26 | 1 | -41/+55 |
* | Add archlinux to the doc | Dhananjay Balan | 2013-03-21 | 1 | -1/+21 |
* | Add the --list-deps option to the set builder command. | Chris Johns | 2013-03-09 | 1 | -4/+9 |
* | Macro %define updates an existing macro. | Chris Johns | 2013-03-08 | 1 | -2/+6 |
| | | | | | Analysis of the current script shows a number of updates are happening and this should be the default. |
