* | devel/glib: Fix the checksum for the patch | Chris Johns | 2020-04-27 | 1 | -1/+2 |
* | source-builder: Add capstone | Vijay Kumar Banerjee | 2020-04-10 | 2 | -0/+34 |
* | bare/config: Add devel/dtc-1.6.0 | Vijay Kumar Banerjee | 2020-04-10 | 1 | -0/+18 |
* | bare/glib-2.48.2: Add patches to suppress null string warning | Vijay Kumar Banerjee | 2020-04-10 | 1 | -0/+7 |
* | qemu-couverture: update to qemu-stable-4.0.0 | Vijay Kumar Banerjee | 2020-04-10 | 2 | -13/+8 |
* | rsb: Use dtc.bset for Spike | Hesham Almatary | 2020-04-09 | 1 | -1/+1 |
* | rsb: Bump DTC to 1.4 version | Hesham Almatary | 2020-04-09 | 1 | -1/+1 |
* | bare: Fix pkgconfig checks and getting source. | Chris Johns | 2020-03-27 | 8 | -8/+8 |
| | | | | | | | - If the package was installed the check does not build the package. This also meant getting the source failed. Closes #3919 | ||||
* | bare/glib: Add back glib-2.39.3-1 | Chris Johns | 2020-03-27 | 1 | -0/+22 |
| | | | | | - It was removed in ... https://git.rtems.org/rtems-source-builder/commit/?id=f93fcef875560f6a8ac7a3a541e4a96f73751553 | ||||
* | spike: Update to use exec that searches along PATH. | Joel Sherrill | 2020-03-25 | 1 | -2/+3 |
| | | | | Updates #3914. | ||||
* | Spike: Update to include fix for hard-coded path to dtc | Joel Sherrill | 2020-03-23 | 1 | -2/+2 |
| | | | | Closes #3914. | ||||
* | qemu: Update glib to build on newer gcc | Martin Erik Werner | 2020-03-20 | 2 | -4/+4 |
| | | | | | | | | | | | | | | | | | | | Update the glib version to 2.48.2 in order to fix build failure on newer gcc[0]. Force internal version of libpcre for glib, since otherwise the build failed, presumably since libpcre is not provided as a module (maybe it should?). Increasing the glib version further to the current latest was not tested. [0] CC libglib_2_0_la-gdate.lo ../../glib-2.39.3/glib/gdate.c: In function 'g_date_strftime': ../../glib-2.39.3/glib/gdate.c:2497:7: error: format not a string literal, format string not checked [-Werror=format-nonliteral] tmplen = strftime (tmpbuf, tmpbufsize, locale_format, &tm); ^~~~~~ | ||||
* | sis simulator: update to version 2.21 | Jiri Gaisler | 2020-03-06 | 1 | -2/+2 |
| | | | | | | | | * Fix incorrect operation on big-endian hosts * Avoid reserved word sparc * Initialize PC before connecting to gdb | ||||
* | qemu-couverture-git-1.cfg: Use an identifiable name for the download file. | Joel Sherrill | 2019-12-13 | 1 | -2/+2 |
| | | | | closes #3808. | ||||
* | Update sis to v2.20 | Jiri Gaisler | 2019-11-14 | 1 | -2/+2 |
| | | | | | * Support gdb async break on all platforms * Support ctrl-c on win32 | ||||
* | rsb: Update RISC-V's Spike revision | Hesham Almatary | 2019-11-12 | 1 | -13/+2 |
| | | | | | | | | Latest Spike integrated fesvr in its source directory, so there is no separate fesvr anymore. Also use a revision of Spike that fixes the file permissions when getting installed. | ||||
* | Update sis simulator to v2.19 | Jiri Gaisler | 2019-11-09 | 1 | -2/+2 |
| | | | | | | | * Improve gdb watchpoint handling/reporting * Support building on Mingw-W64 * Stop flushing sparc reg windows on gdb break * updates #3816 | ||||
* | Update sis to v2.18 | Jiri Gaisler | 2019-11-02 | 1 | -2/+2 |
| | | | | | * Support for gdb watchpoints * Fix build problems on cygwin (closes #3807) | ||||
* | bare/spike: Fix %hash lines, change to base64 checksums. | Chris Johns | 2019-10-28 | 1 | -3/+6 |
* | devel/libiconv: Add a hash. | Chris Johns | 2019-10-28 | 1 | -0/+2 |
* | dtc-1.2.0.cfg: Switch to sha512 so it builds | Joel Sherrill | 2019-10-25 | 1 | -1/+1 |
* | Update Spike RSB recipe and correct installed permissions | Joel Sherrill | 2019-10-23 | 2 | -3/+8 |
| | | | | Updates #3802. | ||||
* | automake-1.12.6: Fix build issues | Sebastian Huber | 2019-09-18 | 1 | -0/+6 |
| | | | | Patch copied from "rtems/config/tools/rtems-automake-1.12.6-1.cfg". | ||||
* | 5/llvm: Add LLVM as a package for RTEMS. | Chris Johns | 2019-09-16 | 2 | -0/+39 |
| | | | | | | | | | | | | | - Add '%source download <source>' to only download the source and do not unpack and prep. This can used when a package internally needs another source package. - Install the staging root only if it is present. A package may internally build another package that is not staged as it is not suitable for installing. Updates #3250 Updatew #3797 | ||||
* | bare/pcre: Add PCRE 8.40 | Chris Johns | 2019-09-16 | 1 | -0/+19 |
* | Added qemu 4.1.0 as bare target | Jiri Gaisler | 2019-08-22 | 3 | -0/+109 |
| | | | | * target name is devel/qemu4, old qemu preserved as devel/qemu | ||||
* | devel/sis: Fix building the SIS on FreeBSD | Chris Johns | 2019-07-23 | 1 | -3/+2 |
| | | | | | | | - Update to SIS 2.17 which has internal readline support for the hosts which do not have readline. Closes #3763 | ||||
* | Add bare target to build standalone sis (devel/sis) | Jiri Gaisler | 2019-06-18 | 2 | -0/+26 |
* | rsb: Update RISC-V's Spike revision | Hesham Almatary | 2018-11-12 | 1 | -2/+2 |
* | windows: Remove BuildRoot from all configs, add a short tmp path. | Chris Johns | 2018-11-05 | 1 | -1/+0 |
| | | | | Closes #3562. | ||||
* | bare/devel: Add qemu-couverture support. | Chris Johns | 2018-05-01 | 2 | -0/+68 |
| | | | | | Add a build set and configuration to build a QEMU we can use for coverage testing. | ||||
* | The libexpat project has moved to github. Fetch expat from github. | Chris Johns | 2018-03-05 | 1 | -1/+2 |
| | | | | Close #3315 | ||||
* | sb: Switch some md5 hashes to sha256 | Stephan Gambke | 2018-02-05 | 6 | -11/+11 |
| | | | | | Using md5 hashes will break the building of qemu.bset, so switch all involved hashes to sha256 | ||||
* | RSB - RISC-V: Add scripts to build RISC-V's simulator | Hesham Almatary | 2017-10-28 | 2 | -0/+28 |
| | | | | Update #3109 | ||||
* | 4.12: Update all MD5 hashes to SHA256. | Chris Johns | 2017-10-12 | 4 | -4/+4 |
| | | | | Closes #2536. | ||||
* | bare/qemu: Use git if the RSB is not release or without a release URL. | Chris Johns | 2016-03-18 | 1 | -2/+4 |
| | | | | Updates #2661. | ||||
* | bare/qemu: Fix %endif type. | Chris Johns | 2016-03-18 | 1 | -1/+1 |
* | bare/qemu: Use a tarfile is the RSB is released. | Chris Johns | 2016-03-18 | 1 | -5/+5 |
* | bare: Update or1ksim-master.zip hash | Chris Johns | 2016-03-17 | 1 | -0/+1 |
| | | | | Updates #2657. | ||||
* | bare: Correct the libffi-3.0.13 hash. | Chris Johns | 2016-03-17 | 1 | -1/+1 |
* | bare: Update qemu package source hashes that are missing. | Chris Johns | 2016-03-17 | 2 | -0/+3 |
| | | | | | | | | Add support for pkgconfig checks to fail when just downloading the source so it is actually downloaded on hosts that may have a package installed. Updates #2657. | ||||
* | bare/devel/qemu: Add a hash for glib. | Chris Johns | 2016-03-16 | 1 | -0/+2 |
| | | | | Closes #2646. | ||||
* | bare/devel/qemu: Fix the release URL logic and pkconfig python3 issues. | Chris Johns | 2016-03-16 | 1 | -1/+1 |
| | | | | Closes #2645. | ||||
* | qemu: Add a package name to create a tarball. | Chris Johns | 2016-03-07 | 1 | -0/+5 |
* | bare/devel: Add missing checksums. | Chris Johns | 2015-06-05 | 3 | -0/+3 |
* | devel/qemu: Update to the current head of Qemu's git master branch. | Chris Johns | 2015-06-03 | 1 | -1/+1 |
* | Apply QEMU patch for openrisc that handles halt signals | Hesham ALMatary | 2015-04-03 | 1 | -0/+7 |
* | 4.11/moxie: Fix the broken dtc-1.4.1 build. | Chris Johns | 2015-03-12 | 1 | -0/+18 |
* | Add the host name to the package name. | Chris Johns | 2015-01-18 | 3 | -3/+3 |
| | | | | | | Adding the host name results in the tar files created by the --bset-tar-file and --pkg-tar-files to contain the host name. This is useful when building Cxc packages. | ||||
* | rtems4.11: Update DTC for Moxie to it's new home path. | Chris Johns | 2014-12-12 | 1 | -0/+2 |
| | | | | | | Add a suitable hash for the build to proceed. Closes #2202. |
