Using md5 hashes will break the building of qemu.bset,
so switch all involved hashes to sha256
Closes #2646.
Remove the 'opt' from various macros and shell variables.
Add pkgconfig to the checks to make it clear the check is a
pkgconfig check.
Add NTP support as the first package to be built using the RSB.
Split the RTEMS URL's out from the base bset file into a separate
file that be included by other files.
Add an RTEMS BSP configuration file to help abstract the process
of building 3rd party packages.
Clean the cross and canadian cross support up so we can cleanly support
cross and canadian cross building.
Refactor the pkgconfig support and clean up the PC file handling of
loading modules.
Add support for %{?..} to return false if a macro is %{nil}.
Add %{pkgconfig ..} support to allow better control of access RTEMS
pkgconfig files.
Add the extra actions: ccflags, cflags, ldflags and libs to allow the
fetching of these from pkg-config files.
Update configuration to build on FreeBSD. This is based on pkg-config
detecting the packages installed on the host.
Qemu requires gettext, glib, libffi, and pixman. DTC is built
as a submodule.
On Mavrick provide a pkg-config command so avoid needing a pkgconfig.
The one here is only just good enough to work.
Provide an internal autotools build including libtool so qemu can
be built from git.
