2018-03-05 | The libexpat project has moved to github. Fetch expat from github. | Chris Johns | 1 | -1/+2 | |
Close #3315 | |||||
2017-10-12 | 4.12: Update all MD5 hashes to SHA256. | Chris Johns | 1 | -1/+1 | |
Closes #2536. | |||||
2014-07-29 | Add checksum support for downloaded files. | Chris Johns | 1 | -0/+2 | |
File download by http, ftp, pw support checksum. The %hash directive provides a means of setting a hash used to checksum the file. Files on disk or just downloaded are checked. | |||||
2013-05-14 | Add bare/config and move the source-builder/config to it. | Chris Johns | 1 | -0/+0 | |
Rework the RTEMS build set files to point to the new location. Move the files into devel, this follows the ports naming in FreeBSD. Update the macros, defaults, and options to support this. | |||||
2012-11-06 | Move into the source-builder tree. | Chris Johns | 1 | -0/+0 | |
2012-11-05 | Cleaned up configuration. Allow the sb-builder to directly build packages. | Chris Johns | 1 | -2/+2 | |
2012-11-05 | Clean up the configurations. Add internal/external autotools support. | Chris Johns | 1 | -5/+0 | |
2012-10-31 | Add expat and gdb support. | Chris Johns | 1 | -0/+21 | |
