* | 6: Update tool chain | Sebastian Huber | 2021-03-16 | 3 | -6/+6 |
* | sb/config.py: Fix operator reconstruction | Ricardo Cárdenes | 2021-03-11 | 1 | -3/+3 |
| | | | | Close #4335 | ||||
* | Add recipe for building rtems-net-legacy | Vijay Kumar Banerjee | 2021-03-10 | 3 | -0/+94 |
* | sb/config.py: Fix relational operator | Vijay Kumar Banerjee | 2021-03-10 | 1 | -1/+1 |
| | | | | Close #4319 | ||||
* | 7: Update tool chain | Sebastian Huber | 2021-03-09 | 3 | -8/+8 |
* | 6: Update tool chain | Sebastian Huber | 2021-03-09 | 3 | -8/+8 |
* | 7: Update tool chain | Sebastian Huber | 2021-03-08 | 3 | -8/+8 |
* | 6: Update tool chain | Sebastian Huber | 2021-03-08 | 3 | -8/+8 |
* | 7: Update tool chain | Sebastian Huber | 2021-03-05 | 3 | -8/+8 |
* | 6: Update tool chain | Sebastian Huber | 2021-03-05 | 3 | -8/+8 |
* | 7: Update tool chain | Sebastian Huber | 2021-02-05 | 3 | -8/+8 |
* | 6: Update tool chain | Sebastian Huber | 2021-02-05 | 3 | -8/+8 |
* | 6: Update tool chain | Sebastian Huber | 2021-01-26 | 3 | -8/+8 |
| | | | | Close #3937. | ||||
* | 7: Update tool chain | Sebastian Huber | 2021-01-25 | 3 | -8/+8 |
* | 6: Use release branches for Binutils/GDB | Sebastian Huber | 2021-01-22 | 6 | -12/+35 |
* | 6/7: Update unstable RTEMS 6/7 tool chain | Sebastian Huber | 2021-01-21 | 4 | -12/+12 |
* | 6/7: Update unstable RTEMS 6/7 tool chain | Sebastian Huber | 2021-01-20 | 4 | -12/+12 |
* | 6: Add FPH2 multilib for nios2 | Sebastian Huber | 2021-01-17 | 1 | -0/+3 |
| | | | | Update #4215. | ||||
* | 6/7: Update unstable RTEMS 6/7 tool chain | Sebastian Huber | 2021-01-17 | 4 | -8/+8 |
* | 6/7: Update unstable RTEMS 6/7 tool chain | Sebastian Huber | 2021-01-14 | 4 | -12/+12 |
* | 6/7: Update unstable RTEMS 6/7 tool chain | Sebastian Huber | 2021-01-14 | 4 | -8/+8 |
* | 6/7: Update unstable RTEMS 6/7 tool chain | Sebastian Huber | 2021-01-04 | 4 | -8/+8 |
* | 6/7: Update to the latest rtems-tools | Sebastian Huber | 2021-01-04 | 1 | -2/+2 |
| | | | | Update #4202. | ||||
* | 6/7: Update unstable RTEMS 6/7 tool chain | Sebastian Huber | 2020-12-22 | 4 | -8/+8 |
* | 6/7: Update unstable RTEMS 6/7 tool chain | Sebastian Huber | 2020-12-21 | 4 | -12/+12 |
* | Add GMP as a prerequisite for GDB | Sebastian Huber | 2020-12-21 | 4 | -0/+81 |
* | expat: Disable shared libraries | Sebastian Huber | 2020-12-21 | 1 | -1/+2 |
| | | | | | This should ensure that GDB is linked using the static libexpat.a built by the RSB. | ||||
* | devel/sis: Update to 2.26 | Jiri Gaisler | 2020-12-18 | 1 | -2/+2 |
* | 6/7: Update to the latest rtems-tools | Sebastian Huber | 2020-12-16 | 1 | -2/+2 |
* | 6/7: Update unstable RTEMS 6/7 tool chain | Sebastian Huber | 2020-12-15 | 2 | -8/+8 |
| | | | | | | This update includes a fix for the ARM Cortex-R52 support in Newlib. Update #4198. | ||||
* | 6/7: Add multilib for ARM Cortex-R52 processor | Sebastian Huber | 2020-12-03 | 2 | -4/+4 |
| | | | | Close #4198. | ||||
* | 6: Add support for gcov info section | Sebastian Huber | 2020-12-02 | 1 | -0/+3 |
| | | | | Update #4196. | ||||
* | 6/7: Update to the latest rtems-tools | Sebastian Huber | 2020-12-02 | 1 | -2/+2 |
| | | | | Close #4195. | ||||
* | devel/sis: Update to 2.25 | Sebastian Huber | 2020-12-02 | 1 | -5/+4 |
| | | | | Update #4195. | ||||
* | 6/7: Update unstable RTEMS 6/7 tool chain | Sebastian Huber | 2020-12-01 | 2 | -8/+8 |
| | | | | Close #4193. | ||||
* | devel/qemu: Add the hash for the QEMU 5.2.0-rc1 | Chris Johns | 2020-11-16 | 1 | -3/+3 |
* | devel/qemu: Update QEMU to 5.2.0-rc1 | Chris Johns | 2020-11-13 | 5 | -35/+164 |
| | | | | | - This version of qemu uses meson and ninja to build. You will need to install ninja to build. No checks are made until meson run | ||||
* | 6/7: Update unstable RTEMS 6/7 tool chain | Sebastian Huber | 2020-11-02 | 4 | -12/+12 |
* | 6/7: Update unstable RTEMS 6/7 tool chain | Sebastian Huber | 2020-10-28 | 4 | -12/+12 |
* | 6/7: Update unstable RTEMS 6/7 tool chain | Sebastian Huber | 2020-10-26 | 4 | -12/+12 |
* | 6/7: Update unstable RTEMS 6/7 tool chain | Sebastian Huber | 2020-10-12 | 5 | -16/+12 |
* | pkgconfig.py: Removed use of "unicode" keyword for python3 compatibility | Stephen Clark | 2020-09-26 | 1 | -6/+17 |
| | | | | Closes #4094. | ||||
* | patch gcc i386 multiarch | Michael Davidsaver | 2020-09-21 | 1 | -0/+4 |
| | | | | | | | | | | | | Add patch to change from mtune to march when building multilibs. The mtune argument tunes or optimizes for a specific CPU model but does not ensure the generated code is appropriate for the CPU model. Prior to this patch, i386 compatible code was always generated but tuned for later models. This is the same fix as #2830 but applying to gcc 10. Updates #4084. | ||||
* | 6/7: Update unstable RTEMS 6/7 tool chain | Sebastian Huber | 2020-09-18 | 4 | -12/+12 |
* | 6: Update to the latest rtems-tools | Sebastian Huber | 2020-09-18 | 1 | -3/+2 |
* | Add sis to RISC-V build | Jiri Gaisler | 2020-09-10 | 1 | -0/+1 |
* | devel/sis: Update to 2.22 | Chris Johns | 2020-09-10 | 1 | -2/+3 |
* | rsb: Fix the documentation URL | Hesham Almatary | 2020-09-09 | 1 | -1/+1 |
* | rtems: Update to the latest rtems-tools | Chris Johns | 2020-09-07 | 1 | -2/+3 |
* | 6/7: Update unstable RTEMS 6/7 tool chain | Sebastian Huber | 2020-09-04 | 4 | -12/+12 |
