* | 6: Update unstable RTEMS 6 tool chain | Sebastian Huber | 2020-06-29 | 3 | -6/+6 | |
* | sqlite: Change to https for downloading the source package. | Chris Johns | 2020-06-26 | 1 | -3/+3 | |
* | glib: Gnome has change the git version to gitlab in requested patches. | Chris Johns | 2020-06-25 | 1 | -1/+1 | |
* | rtems: Update kernel, libbsd and tool the master. | Chris Johns | 2020-06-23 | 3 | -6/+6 | |
| | | | | This aligns them to the branch point. | |||||
* | 6: Update unstable RTEMS 6 tool chain | Sebastian Huber | 2020-06-10 | 3 | -8/+8 | |
* | devel/qemu4: Use release source tarball | Chris Johns | 2020-06-10 | 1 | -25/+9 | |
| | | | | | | | Git cannot be used for a release as our release process does not package the source in a manner qemu expects. Closes #3976 | |||||
* | 6: Update unstable RTEMS 6 tool chain | Sebastian Huber | 2020-06-05 | 3 | -8/+8 | |
* | 6: Update unstable RTEMS 6 tool chain | Sebastian Huber | 2020-06-02 | 1 | -2/+2 | |
* | 6: Update unstable RTEMS 6 tool chain | Sebastian Huber | 2020-06-02 | 3 | -8/+8 | |
* | 6: Update unstable RTEMS 6 tool chain | Sebastian Huber | 2020-05-12 | 3 | -11/+8 | |
* | re/pixman: Revert the accidental commit. | Chris Johns | 2020-05-08 | 2 | -2/+2 | |
| | | | | - Move qemu to 0.40.0 so pixman builds on FreeBSD 12 | |||||
* | rtems: Update the kernel | Chris Johns | 2020-05-08 | 1 | -2/+2 | |
* | bare/qemu: Fixes building on FreeBSD | Chris Johns | 2020-05-08 | 6 | -261/+141 | |
| | | | | | | | | | | | | | | | - Move the qemu config to a common file shared by qemu and qemu4. - Disable nettle on qemu4, FreeBSd complained. - Add some extra git cleaning steps to the git path. These however do not full clean the qemu submodules and it is not worth the effort to try and fix. - The devel/qemu will not build on machines with python set to python3. This will not be fixed, use qemu4. Closes #3966 | |||||
* | sb: Disable any trace data | Chris Johns | 2020-05-08 | 1 | -2/+2 | |
* | sb: Add git clean to the supported git commands. | Chris Johns | 2020-05-08 | 2 | -0/+17 | |
* | qemu4.bset: Update to pixman 0.40.0. | Joel Sherrill | 2020-05-08 | 2 | -1/+20 | |
* | rtems: Update the kernel and tools packages to the latest RTEMS 5 | Chris Johns | 2020-05-07 | 2 | -4/+4 | |
* | rtems-kernel: Update to the latest | Chris Johns | 2020-04-28 | 1 | -2/+2 | |
* | devel/dtc: Change the home page to www.devicetree.org | Chris Johns | 2020-04-28 | 1 | -1/+1 | |
* | rtems-bsb: Use linker garbage collection for BSP based builds | Chris Johns | 2020-04-28 | 1 | -1/+10 | |
| | | | | Close #3944. | |||||
* | rtems-libbsd: Remove the v from the package name verision | Chris Johns | 2020-04-28 | 1 | -1/+1 | |
* | 6: Update unstable RTEMS 6 tool chain | Sebastian Huber | 2020-04-28 | 3 | -8/+8 | |
* | rtems-kernel: Fix building without the rtems test option. | Chris Johns | 2020-04-28 | 1 | -2/+0 | |
| | | | | Updates #3956 | |||||
* | rtems-kernel: Install tests when tests are built | Chris Johns | 2020-04-28 | 1 | -32/+61 | |
| | | | | | | | | | | The tests in RTEMS are not installed so if a user requests the tests be built install them. Given the RSB cleans up building the tests and not installing does nothing. - Fix the options handling the kernel build to be consistent Updates #3956 | |||||
* | source-builder/config/gdb-common-1.cfg: Fix building with Python 3.8 | Anders Montonen | 2020-04-28 | 1 | -1/+6 | |
| | | | | | | | | | | Starting with Python 3.8, python3-config requires the "--embed" flag to print the flags required for embedding Python in an application. Fixes: error: shell macro failed: /home/anders/work/rtems/rsb/source-builder/sb/rtems-build-dep -c gcc -l : 2: error: no library (-l) provided Signed-off-by: Anders Montonen <Anders.Montonen@iki.fi> | |||||
* | sb/linux.py: Workaround for Python >= 3.8 | Anders Montonen | 2020-04-28 | 1 | -7/+11 | |
| | | | | | | | | | | | | | | | The platform.dist() interface has been deprecated since Python 3.5, and has been removed in Python 3.8. Fixes: Traceback (most recent call last): File "/home/anders/work/rtems/rsb/source-builder/sb/options.py", line 682, in load overrides = linux.load() File "/home/anders/work/rtems/rsb/source-builder/sb/linux.py", line 60, in load distro = platform.dist()[0] AttributeError: module 'platform' has no attribute 'dist' Signed-off-by: Anders Montonen <Anders.Montonen@iki.fi> | |||||
* | sb: Fix Python literal comparison warnings | Anders Montonen | 2020-04-28 | 2 | -30/+30 | |
| | | | | | | | Fixes: SyntaxWarning: "is" with a literal. Did you mean "=="? Signed-off-by: Anders Montonen <Anders.Montonen@iki.fi> | |||||
* | devel/glib: Fix the checksum for the patch | Chris Johns | 2020-04-27 | 1 | -1/+2 | |
* | 5/rtems-libbsd: Update 5-freebsd-12 | Christian Mauderer | 2020-04-20 | 1 | -2/+2 | |
* | 5/rtems-libbsd: Update 5-freebsd-12 | Christian Mauderer | 2020-04-17 | 1 | -2/+2 | |
* | 6: Update unstable RTEMS 6 tool chain | Sebastian Huber | 2020-04-17 | 3 | -8/+8 | |
* | 5/rtems-libbsd: Update 5-freebsd-12 | Christian Mauderer | 2020-04-16 | 1 | -2/+2 | |
* | 5/rtems: Update kernel and libbsd. | Christian Mauderer | 2020-04-15 | 2 | -4/+4 | |
* | source-builder: Add capstone | Vijay Kumar Banerjee | 2020-04-10 | 3 | -0/+96 | |
* | bare/config: Add devel/dtc-1.6.0 | Vijay Kumar Banerjee | 2020-04-10 | 1 | -0/+18 | |
* | bare/glib-2.48.2: Add patches to suppress null string warning | Vijay Kumar Banerjee | 2020-04-10 | 1 | -0/+7 | |
* | qemu-couverture: update to qemu-stable-4.0.0 | Vijay Kumar Banerjee | 2020-04-10 | 2 | -13/+8 | |
* | rsb: Use dtc.bset for Spike | Hesham Almatary | 2020-04-09 | 1 | -1/+1 | |
* | rsb: Bump DTC to 1.4 version | Hesham Almatary | 2020-04-09 | 1 | -1/+1 | |
* | rsb: Fix Spike build | Hesham Almatary | 2020-04-09 | 1 | -3/+2 | |
| | | | | | | * There is no all$ target in Spike * There is no longer --with-fesvr flag since fesvr is source-inlined by default | |||||
* | 6: Update unstable RTEMS 6 tool chain | Sebastian Huber | 2020-04-08 | 1 | -2/+2 | |
| | | | | Update #3937. | |||||
* | 6: Update unstable RTEMS 6 tool chain | Sebastian Huber | 2020-04-07 | 1 | -0/+3 | |
* | rtems: bump rtems-5-kernel | Gedare Bloom | 2020-04-06 | 1 | -2/+2 | |
* | rtems/libbsd: Update to origin/5-freebsd12 HEAD. | Chris Johns | 2020-04-06 | 1 | -4/+4 | |
* | rtems/kernel: Update to origin/master HEAD. | Chris Johns | 2020-04-06 | 1 | -2/+2 | |
* | 6: Update unstable RTEMS 6 tool chain | Sebastian Huber | 2020-04-06 | 3 | -8/+8 | |
* | sb/reports: add sanitize parameter enabled for --mail | Gedare Bloom | 2020-04-04 | 2 | -21/+35 | |
| | | | | | | | | Adds a --sanitize option to command line for reports.py and also for the reports.report() interface from setbuilder.py to remove the Remotes information from git. Closes #3887. | |||||
* | databases/sqlite: Update to 3.31.1 | Jonathan Brandmeyer | 2020-04-02 | 4 | -47/+49 | |
| | | | | closes #3927. | |||||
* | sb/reports.py: Remove spurious error check | Gedare Bloom | 2020-04-01 | 1 | -2/+0 | |
| | | | | | The error path is taken when list-bsets or list-cfgs returns true (meaning it listed them). So the error is invalid. | |||||
* | rtems/libbsd: Update to the latest 5-freebsd12 branch head. | Chris Johns | 2020-03-30 | 1 | -2/+2 | |
