* | Remove aarch64 and microblaze from RSB on 5 branch5.35 | Joel Sherrill | 2023-01-30 | 4 | -10/+0 |
| | | | | Closes #4555. | ||||
* | sb: Find the top when a release | Chris Johns | 2022-12-18 | 1 | -0/+2 |
| | | | | Closes #4777 | ||||
* | rtems: Add back gcc-4.6 build configuration5.2 | Chris Johns | 2022-11-16 | 1 | -0/+28 |
| | | | | Updates #4715 | ||||
* | rtems: Update source and patch URLs to valid locations | Chris Johns | 2022-11-15 | 7 | -6/+14 |
* | sb/downloads: Raise errors on no hash present | Chris Johns | 2022-11-15 | 1 | -3/+1 |
| | | | | Close #4761 | ||||
* | rtems: Update source and patch URLs to valid locations | Chris Johns | 2022-11-14 | 13 | -41/+97 |
* | rtems/net-snmp: Update to 5.9.3 with the RTEMS patch | Chris Johns | 2022-11-14 | 4 | -44/+75 |
| | | | | | | | | The 5.7.2.1 patch referenced in the configuration cannot be located so update the version to the latest. Checked with Zynq A9 qemu and libbsd. Closes #4758 | ||||
* | bare/gcc: Remove gcc-4.8.2 because newlib references the unsupported CVS | Chris Johns | 2022-11-14 | 2 | -72/+0 |
* | gdb: Use https for downloads | Sebastian Huber | 2022-11-11 | 1 | -1/+1 |
| | | | | Close #4754 | ||||
* | 5: Update RTEMS, LibBSD and Tools builds to the latest 5 hash | Chris Johns | 2022-10-22 | 3 | -6/+6 |
* | rtems/bsps: Optionally support arch/bsp if used | Chris Johns | 2022-09-30 | 1 | -14/+41 |
| | | | | Updates #4717 | ||||
* | sb/set-bulder: Fix installing builds when a single buildset | Chris Johns | 2022-09-30 | 1 | -8/+7 |
| | | | | | | | | - Always stage a build - Install if installable and outter most buildset instance Closes #4731 | ||||
* | sb/execute: Fix incremental decoder with --dry-run | Chris Johns | 2022-09-30 | 1 | -2/+5 |
| | | | | Closes #4734 | ||||
* | sb/execute: Use a decoder that maintains state aross blocks | Chris Johns | 2022-09-30 | 1 | -1/+3 |
| | | | | Update #4734 | ||||
* | sb/version: Set top from external package | Chris Johns | 2022-09-30 | 1 | -1/+9 |
| | | | | Closes #4733 | ||||
* | sb/set-builder: Fix staging and tar file generation with a single config build | Chris Johns | 2022-09-29 | 1 | -16/+6 |
| | | | | Closes #4731 | ||||
* | sb/setbuilder: Install the build when stagging or configured to install | Chris Johns | 2022-09-17 | 1 | -3/+6 |
| | | | | Updates #4716 | ||||
* | rtems/kernel: Support deployment standard buildset configs | Chris Johns | 2022-09-16 | 1 | -10/+39 |
| | | | | | | - Check and optionally support arch/bsp format 'with_rtems_bsp' defines Updates #4717 | ||||
* | sb/setbuilder: Do not install if --no-install option is used | Chris Johns | 2022-09-16 | 1 | -1/+2 |
| | | | | | | - This is a bug introduced in the recent bset tar file changes Updates #4716 | ||||
* | sb/setbuilder: Correctly create build set tar files | Chris Johns | 2022-09-16 | 2 | -24/+39 |
| | | | | | | | | | | | | - Make a single tarfile for all buildsets built - Use the staging tree as the tarfile source - Use python's tarfile module - Create a config.file object without loading a .cfg file Updates #4716 | ||||
* | sb/config: Correctly handle multiple config paths | Chris Johns | 2022-09-14 | 2 | -28/+26 |
| | | | | | | | | | - Add rtems/config to the config directories searched to better support deployment - Correctly expand the configdir and path searchs Updates #4716 | ||||
* | sb/setbuilder: Support line continuation | Chris Johns | 2022-09-14 | 1 | -1/+13 |
* | sb/getsources: Fixes to configurations | Chris Johns | 2022-09-08 | 6 | -6/+100 |
* | sb: Back port fixes from the development branch | Chris Johns | 2022-09-08 | 3 | -85/+133 |
* | sb/getsources: Fix getting sources | Chris Johns | 2022-09-08 | 2 | -563/+771 |
| | | | | | | - Back ported from the development branch Updates #4715 | ||||
* | Add QEMU 5 configuration files | Ryan Long | 2022-08-23 | 5 | -2/+198 |
* | glib-2.48.2-1.cfg: Fix checksum of patch | Ryan Long | 2022-08-23 | 1 | -1/+1 |
* | devel/spike-1.1.0: bump hash | Ryan Long | 2022-06-02 | 1 | -2/+2 |
| | | | | | | Bump the hash of spike to match the 1.1.0 release Closes #4660 | ||||
* | sb: Merge mailer changes from rtems-tools | Alex White | 2021-12-16 | 3 | -33/+189 |
| | | | | | | This adds the improved mailer.py script from rtems-tools. Closes #4554 | ||||
* | devel/qemu4: Add patches so qemu4 can build | Ryan Long | 2021-12-15 | 2 | -0/+4 |
| | | | | | | | These patches add patches that fix the build issues preventing qemu4 from building on Ubuntu. Closes #4561 | ||||
* | devel/dtc: Bump dtc hash to match rtems6 | Ryan Long | 2021-12-15 | 3 | -2/+20 |
| | | | | | | Bumped dtc version to get rid of build failure for dtc. Closes #4562 | ||||
* | rtems-gdb-9.1-1.cfg: Add patch for Cygwin | Joel Sherrill | 2021-10-13 | 1 | -0/+7 |
| | | | | | | | | | The patch is needed to address link failures introduced when Cygwin apparently changed their base address for executables. This is not an issue with gdb 10 and this is a minimalistic approach to addressing this failure on the 5 branch. Closes #4523. | ||||
* | rtems-tools: Pick up fix for modern llvm | Christian Mauderer | 2021-08-17 | 1 | -2/+2 |
| | | | | Closes #4495 | ||||
* | gdb-9-1: Add patch to fix linker error with gcc10 | Vijay Kumar Banerjee | 2021-03-30 | 1 | -0/+3 |
| | | | | Close #4366 | ||||
* | sb/config.py: Fix operator reconstruction | Ricardo Cárdenes | 2021-03-11 | 1 | -3/+3 |
| | | | | Close #4337 | ||||
* | sb/config.py: Fix relational operator | Vijay Kumar Banerjee | 2021-03-10 | 1 | -1/+1 |
| | | | | Close #4330 | ||||
* | Add patch to newlib for devctl.h to compile with C++ | Joel Sherrill | 2020-12-10 | 1 | -0/+4 |
| | | | | Closes #4174. | ||||
* | pkgconfig.py: Removed use of "unicode" keyword for python3 compatibility | Stephen Clark | 2020-09-26 | 1 | -1/+17 |
| | | | | Closes #4094. | ||||
* | patch gcc i386 multiarch | Michael Davidsaver | 2020-09-21 | 1 | -0/+4 |
| | | | | | | | | | | Add patch to change from mtune to march when building multilibs. The mtune argument tunes or optimizes for a specific CPU model but does not ensure the generated code is appropriate for the CPU model. Prior to this patch, i386 compatible code was always generated but tuned for later models. Closes #2830. | ||||
* | 5/kernel, 5/libbsd: Update the head of the 5 branch5.1 | Chris Johns | 2020-08-24 | 2 | -4/+4 |
* | 5/kernel, 5/libbsd: Update the head of the 5 branch | Chris Johns | 2020-08-13 | 2 | -4/+4 |
* | bare/libusb: Fix the configuration and add a hash | Chris Johns | 2020-08-11 | 2 | -1/+6 |
| | | | | Updates #4014 | ||||
* | 5: Remove unused configuration files for the release | Chris Johns | 2020-08-11 | 236 | -6186/+0 |
* | rtems: Remove RTEMS 6 build sets. | Chris Johns | 2020-08-11 | 25 | -178/+0 |
* | sb/options: A Canadian Cross is a different host, build and target | Chris Johns | 2020-06-30 | 1 | -6/+5 |
| | | | | | | The check must make sure each is different. Closes #4017 | ||||
* | sqlite: Change to https for downloading the source package. | Chris Johns | 2020-06-26 | 1 | -3/+3 |
| | | | | Closes #4015 | ||||
* | glib: Gnome has change the git version to gitlab in requested patches. | Chris Johns | 2020-06-25 | 1 | -1/+1 |
* | rtems: Update kernel, libbsd and tool the master. | Chris Johns | 2020-06-23 | 3 | -6/+6 |
| | | | | This aligns them to the branch point. | ||||
* | 6: Update unstable RTEMS 6 tool chain | Sebastian Huber | 2020-06-10 | 3 | -8/+8 |
* | devel/qemu4: Use release source tarball | Chris Johns | 2020-06-10 | 1 | -25/+9 |
| | | | | | | | Git cannot be used for a release as our release process does not package the source in a manner qemu expects. Closes #3976 |
