* | 4.11: Remove from master. | Chris Johns | 2016-03-16 | 39 | -1028/+1 | |
| | | | | Updates #2649. | |||||
* | 4.12/gdb-7.11: Add ERC32 patches to fix the simulator. | Chris Johns | 2016-03-16 | 1 | -8/+10 | |
| | | | | Updates #2644. | |||||
* | rtems/4.12: Add hash to gdb-7.11. | Chris Johns | 2016-03-15 | 1 | -1/+1 | |
* | sb: Make cvs optional. | Chris Johns | 2016-03-15 | 4 | -3/+4 | |
| | | | | | | | Ignore RSB generated files to keep the git dirty status clean. Closes #2647. Closes #2748. | |||||
* | rtems-kernel: Fix the --with-rtems/--without-rtems support when released. | Chris Johns | 2016-03-14 | 2 | -15/+26 | |
| | | | | | | | | | | | | Also add: --with-rtemsbsp="bsp,bsp,bsp" --with-rtems-smp --with-rtems-tests --with-rtems-tests=sample --with-rtems-tests=all Closes #2526. | |||||
* | sb: Fix the --without-error-report parsing of the label. | Chris Johns | 2016-03-14 | 1 | -2/+2 | |
| | | | | Update #2526. | |||||
* | sb: Update download to check the config file for release URL control. | Chris Johns | 2016-03-14 | 3 | -1/+6 | |
| | | | | | | | | Provide without_release_url support in the configuration file so the release tarball download of the kernel and tools uses the release's top level directory and not the sources directory. Closes #2481. | |||||
* | sb: Fix build's --with-error-report handling. | Chris Johns | 2016-03-14 | 1 | -1/+2 | |
| | | | | | | This reflects changes in the way the --with/--without options are handled. Updates #2526. | |||||
* | 4.12: Update GDB to gdb-7.11. | Chris Johns | 2016-03-14 | 2 | -1/+35 | |
* | 4.12/rtems-moxie.bset: Update to match default RTEMS toolset | Joel Sherrill | 2016-03-11 | 1 | -22/+2 | |
* | Bugfix: gdb-7.3.1 for rtems 4.10 couldn't be built with modern texinfo. | Goetz Pfeiffer | 2016-03-10 | 1 | -0/+2 | |
| | | | | | | | This is fixed by patch file gdb-7.3.1-rtems4.10-20151123.diff from the rtems-tools.git repository. Close #2524. | |||||
* | Bugfix: gcc-4.4.7 for rtems 4.10 couldn't be built with modern texinfo. | Goetz Pfeiffer | 2016-03-10 | 1 | -0/+2 | |
| | | | | | | | This is fixed by patch file gcc-core-4.4.7-rtems4.10-20151123.diff from the rtems-tools.git repository. Update #2524. | |||||
* | Bugfix: binutils-2.20.1 for rtems 4.10 couldn't be built with modern texinfo. | Goetz Pfeiffer | 2016-03-10 | 1 | -1/+3 | |
| | | | | | | | This is fixed by patch file binutils-2.20.1-rtems4.10-20151123.diff from the rtems-tools.git repository. Update #2524. | |||||
* | sb: Fix --without-release-url logic. | Chris Johns | 2016-03-10 | 1 | -2/+2 | |
| | | | | Updates #2636. | |||||
* | sb: Add a download option --with-release-url/--without-release-url. | Chris Johns | 2016-03-10 | 5 | -19/+29 | |
| | | | | | | | | | | | | | | | | | | | | | | | The default without the option is to prepend the release URL to the URL list to download from the RTEMS FTP site first if the RSB is released. This option can force the RTEMS FTP to be tried first when not a release, or you can supply a different URL to download from or you can request no RTEMS URL is tried first. Eg: --with-release-url --with-release-url=file://opt/local/cache --without-release-url Move the RTEMS release URL to the default.mc file. Change the URL to the RTEMS FTP server and do not use the https method of access. The option's with_arg call was cleaned up to make sense. Remove the log's raw output of an extra space. Some download error message formating was cleaned up. Closes #2636. | |||||
* | sb: Fix typo on the urlparse name in download.py | Chris Johns | 2016-03-10 | 2 | -2/+1 | |
| | | | | Updates #2619. | |||||
* | sb: Download's urllib_parse should point to urlparse on Python2. | Chris Johns | 2016-03-10 | 1 | -3/+1 | |
* | sb: Fix configparser import on Python2 in version.py. | Chris Johns | 2016-03-10 | 2 | -3/+4 | |
* | sb: Add support to GDB to select a specific Python. | Chris Johns | 2016-03-08 | 2 | -1/+62 | |
| | | | | | | Detect a suitable Python version on Windows. Update #2619. | |||||
* | sb: Report platform import errors. | Chris Johns | 2016-03-08 | 1 | -0/+2 | |
* | qemu: Add a package name to create a tarball. | Chris Johns | 2016-03-07 | 2 | -1/+6 | |
* | sb: Update code base to support Python3 and Python2. | Chris Johns | 2016-03-07 | 29 | -312/+410 | |
| | | | | | | Fix Windows support to allow MSYS2 Python to be used. Updates #2619. | |||||
* | Clean up 4.9 build issues. | Chris Johns | 2016-03-01 | 5 | -20/+92 | |
| | | | | Add support so 4.9 builds on a recent FreeBSD using clang. | |||||
* | Fix 4.10 and 4.9 building. | rtems | 2016-03-01 | 3 | -1/+3 | |
| | | | | | | Add the 4.9 newlib 1.16.0-20090324 patch. Add a release to the 4.9 RTEMS kernel. Add a release to the 4.10 RTEMS kernel. | |||||
* | 4.12: Add aarch64 and x86_64 support. | Chris Johns | 2016-02-29 | 6 | -1/+44 | |
* | sb: Remove http query flags from the file name if present. | Chris Johns | 2016-02-29 | 1 | -1/+8 | |
| | | | | | | | | The query flags such as '?h=4.11' to select a branch cannot appear in the file name on Windows. This patch removes the query part from the file name. Update #2616. | |||||
* | sb: bootstrap.py clearing of environ var 'ACLOCAL_PATH' on MSYS2 fails. | Chris Johns | 2016-02-29 | 1 | -2/+9 | |
| | | | | | | | With a recent (Feb 2016) pytnon on MSYS2 the clear fails so delete the variable. Update #2613. | |||||
* | config: Patch automake-1.12.6 to remove warning on newer perl versions. | Chris Johns | 2016-02-29 | 2 | -0/+8 | |
| | | | | Closes #2616. | |||||
* | update newlib git revision to get <sys/select.h> RTEMS dependency | Hesham Almatary | 2016-02-27 | 2 | -2/+2 | |
* | Wrap the tar command in double quotes for Windows cmd.exe. | Chris Johns | 2016-02-25 | 1 | -2/+2 | |
| | | | | | | | Windows cmd.exe does not support a single quote for options. Change to a double quote. Closes #2615. | |||||
* | Fix sb-bootrap to run on Windows using MSYS2. | Chris Johns | 2016-02-24 | 1 | -2/+18 | |
| | | | | | | | | Prepend 'sh' to the command so the autoreconf runs in a shell. Is the first item in the path is a reference to MSYS2 remove it. Closes #2613. | |||||
* | Fix pkgconfig for MSYS to allow QEMU to build. | Chris Johns | 2016-02-24 | 2 | -21/+46 | |
* | Fix sb-build to reference the opts correctly. | Chris Johns | 2016-02-24 | 1 | -1/+2 | |
* | Fix the rtems-tools waf --destdir path on Windows. | Chris Johns | 2016-02-22 | 2 | -3/+16 | |
| | | | | | | | | | | | Waf requires the drive be added to the destdir path so it installs to a path the RSB knows. The RSB assumes the destdir contains an MSYS drive path as seen in the POSIX path. This is default for configure scripts. Also fix the git URL to pull before the branch command as well as after to update the branch. Closes #2605. | |||||
* | Update RTEMS 4.12 build set for MIPS | Sebastian Huber | 2016-01-29 | 1 | -0/+3 | |
* | Update RTEMS 4.12 build set | Sebastian Huber | 2016-01-29 | 2 | -1/+23 | |
| | | | | Use Binutils 2.26. | |||||
* | Fix RTEMS Tools source symlink generation. | Patrick Gauvin | 2016-01-28 | 1 | -2/+1 | |
| | | | | | | When rsb_released was not 0, a build failure would occur. closes #2495. | |||||
* | Update RTEMS 4.12 build set | Nick Withers | 2016-01-25 | 2 | -1/+23 | |
| | | | | | Update to the GCC 6 20160124 snapshot, which notionally resolves https://gcc.gnu.org/bugzilla/show_bug.cgi?id=65779 | |||||
* | source-builder/config/qemu-1-1.cfg: Add --disable-smartcard-nss | Joel Sherrill | 2016-01-24 | 1 | -0/+1 | |
| | | | | closes #2547. | |||||
* | Add hashes for RTEMS 4.12 tools | Sebastian Huber | 2016-01-19 | 1 | -0/+6 | |
* | Update RTEMS 4.12 build set | Sebastian Huber | 2016-01-18 | 5 | -35/+41 | |
* | fix libpng version number | YANG Qiao | 2015-12-16 | 2 | -4/+4 | |
* | add dependencies for nxlib | YANG Qiao | 2015-12-16 | 1 | -0/+1 | |
* | add graphics-all bset | YANG Qiao | 2015-12-16 | 1 | -0/+9 | |
* | add dependencies for nanox | YANG Qiao | 2015-12-16 | 1 | -0/+1 | |
* | fix nanox patch url | YANG Qiao | 2015-12-16 | 1 | -4/+4 | |
* | fix t1lib patch url | YANG Qiao | 2015-12-16 | 1 | -1/+1 | |
* | Fix 4.11/rtems-tools so it builds from git. | Chris Johns | 2015-12-15 | 3 | -1/+36 | |
* | Download source from RTEMS if a release. | Chris Johns | 2015-12-14 | 1 | -12/+35 | |
| | | | | | | | | | | | | | | | | Download source from ftp.rtems.org before the package's URL if a release. If a user adds a URL via the command line that is used then the RTEMS release path then the package's URL. A user can add --url=file://path/../morepath to have the RSB use a local cache of source on their hard disk. This is useful if you need to wipe the RSB and start again. Save away the 'sources' and 'patches' directories to a common directory and provide it with via the --url option using the 'file://' prefix. Closes #2482. | |||||
* | Fix the building of the RTEMS Tools from a tar file. | Chris Johns | 2015-12-13 | 3 | -4/+17 | |
