2020-08-26 | Fix the release tag script | Chris Johns | 1 | -0/+6 | |
2020-08-15 | Fix release branch git clones | Chris Johns | 1 | -9/+10 | |
Closes #4051 | |||||
2020-06-23 | Update the tag script to match the branch script | Chris Johns | 1 | -24/+47 | |
This is not tested and will be once we have branched RTEMS 5 | |||||
2019-10-30 | Stop of error (set -e) | Chris Johns | 1 | -0/+2 | |
2019-10-29 | Update to support RTEMS 5 | Chris Johns | 1 | -2/+2 | |
2017-04-06 | Add a release-path to the RSB VERSION file. Add better defaults support. | Chris Johns | 1 | -4/+4 | |
2016-11-18 | Lets the tagging also push the tags. | Chris Johns | 1 | -1/+2 | |
2016-11-16 | Update to the tag puch command. | Chris Johns | 1 | -2/+2 | |
2016-11-15 | Add a rtems-release-tag script to support tagging repositories.4.11.0 | Chris Johns | 1 | -37/+59 | |
