* | Fix release branch git clones | Chris Johns | 2020-08-15 | 1 | -10/+13 |
| | | | | Closes #4051 | ||||
* | Fix the paths in the README | Chris Johns | 2020-04-29 | 1 | -15/+4 |
| | | | | | | | | | - Move URL path generation to the a separate script file - Move info generation to a separate script file - Add markdown to the README.txt.in but filter and do not generate HTML from MD. A lot more work is needed to have this right. Close #3813 | ||||
* | Add a release_url to the arguments for the various steps. | Chris Johns | 2020-02-28 | 1 | -11/+12 |
| | | | | | | - The release_url can be used for testing or to allow deployment by setting the top level URL the source is fetched from. - Move libbsd up in the order so the RSB can get a hash for it. | ||||
* | Provide two paths for release paths the source. | Chris Johns | 2019-12-05 | 1 | -3/+7 |
* | rsb: Set the correct release snapshot path. | Chris Johns | 2019-11-11 | 1 | -0/+3 |
| | | | | Closes #3811 | ||||
* | Stop of error (set -e) | Chris Johns | 2019-10-30 | 1 | -0/+2 |
* | Update to support RTEMS 5 | Chris Johns | 2019-10-29 | 1 | -3/+3 |
* | Add a release-path to the RSB VERSION file. Add better defaults support. | Chris Johns | 2017-04-06 | 1 | -0/+89 |
