2016-06-16 | Add support for long command lines and fix some shell rules on Windows. | Chris Johns | 1 | -1/+1 | |
2016-04-23 | waf: Add the ability to set FreeBSD options on the configure command line. | Chris Johns | 1 | -1/+7 | |
Add --freebsd-options to add specific FreeBSD compile time options to the build. This is a developer tool. | |||||
2016-04-20 | waf: Move the generated content to libbsd_waf.py. | Chris Johns | 1 | -1374/+33 | |
2016-04-18 | Remove the makefile generator. | Chris Johns | 1 | -19/+19 | |
2016-04-18 | Add RTEMS version support, update all python to 2 and 3. | Chris Johns | 1 | -100/+104 | |
Add support to force the RTEMS version. This remove the need for using the --rtems-version command line option if the automatic detection fails. Update all python code to support python 2 and 3. Update rtems_waf to the latest version to support the RTEMS version, check environment variables and to display the CC version. Sort all tests. I think the unsorted list is dependent on the version of python and so would result in repo noise as if it regenerted. | |||||
2015-11-18 | Add .exe extension to test programs | Sebastian Huber | 1 | -29/+29 | |
2015-11-13 | Use latest rtems_waf | Sebastian Huber | 1 | -2/+2 | |
2015-11-12 | Use optimization level -O2 | Sebastian Huber | 1 | -1/+1 | |
2015-11-12 | Python 3 compatibility | Sebastian Huber | 1 | -1/+1 | |
2015-11-12 | dwc_otg: Port to RTEMS | Sebastian Huber | 1 | -0/+2 | |
2015-09-29 | waf: Add x86 include paths for i386 arch | Sebastian Huber | 1 | -0/+3 | |
2015-09-29 | waf: Do not add '.' to standard include path | Sebastian Huber | 1 | -1/+1 | |
2015-09-25 | builder.py: addTargetSourceCPUDependentSourceFiles | Sebastian Huber | 1 | -13/+12 | |
Avoid and delete this function. | |||||
2015-09-25 | Avoid pci_bus.c file rename | Sebastian Huber | 1 | -1/+1 | |
2015-09-01 | Delete superfluous pci_bus.c files | Sebastian Huber | 1 | -29/+14 | |
2015-09-01 | Delete superfluous legacy.c files | Sebastian Huber | 1 | -20/+5 | |
2015-07-31 | waf_generator.py: Move arch header includes | Sebastian Huber | 1 | -2/+2 | |
Make sure that architecture specific header files are found first. | |||||
2015-07-31 | e1000: Add missing file | Sebastian Huber | 1 | -0/+1 | |
2015-06-26 | modified: waf_generator.py Fix incorrect encoding of NET_CFG_GATEWAY_IP and ↵ | Gene Smith | 1 | -3/+3 | |
change _IP_IP ending to _IP. Remove _IP_IP ending from NET_TAP_INTERFACE. modified: wscript Re-generated from "./freebsd-to-rtems -m" based on waf_generator.py | |||||
2015-06-17 | Check if RTEMS is built with POSIX. | Chris Johns | 1 | -2/+4 | |
2015-06-16 | TCPDUMP and PCAP fixes to defines. | Chris Johns | 1 | -97/+97 | |
2015-06-15 | Add tcpdump and libpcap. | Chris Johns | 1 | -20/+222 | |
- Update the file builder generator to handle generator specific cflags and includes. The tcpdump and libpcap have localised headers and need specific headers paths to see them. There are also module specific flags and these need to be passed to the lex and yacc generators. - Add the tcpdump support. | |||||
2015-06-01 | Add conditional support for RTEMS PCI to the waf build. | Chris Johns | 1 | -0/+1 | |
Check for the "rtems/pci.h" header and provide conditional build support with waf to build for BSPs that do not have PCI support. The Makefile build always defines HAVE_RTEMS_PCI_H which is the same state with this change. The PCI calls still exist however they do nothing and return a constant. Any PCI based driver that makes these calls on a BSP that does not have PCI support will not work which is understandable. Either change the driver or add PCI support the BSP. | |||||
2015-05-22 | waf: Check for dlfcn.h header is availavble. | Chris Johns | 1 | -1/+4 | |
2015-05-21 | waf: Add install support. | Chris Johns | 1 | -31/+92 | |
Install to the --prefix path passed to configure. | |||||
2015-05-21 | wscript: Regenerate | Chris Johns | 1 | -5/+46 | |
2015-05-20 | Add INVARIANTS support | Sebastian Huber | 1 | -0/+1 | |
2015-05-20 | wscript: Regenerate. | Chris Johns | 1 | -27/+55 | |
2015-05-20 | wscript: Generate. | Chris Johns | 1 | -0/+1113 | |
