2018-08-31 | userspace-header-gen.py: Revert interpreter change | Sebastian Huber | 1 | -1/+1 | |
2018-08-28 | userspace-header-gen.py: Sort file content | Sebastian Huber | 1 | -8/+21 | |
Sort the file content to make it less dependent on compiler code generation variances. | |||||
2018-08-01 | userspace-header-gen: Special case for Yacc / Lex. | Christian Mauderer | 1 | -1/+31 | |
Some variables generated by Yacc / Lex need a special treatment. That had been done by manual editing of the generated headers in the past. This patch integrate these changes into the generator. | |||||
2017-10-10 | userspace-header-gen.py: Python 3 compatibility | Sebastian Huber | 1 | -1/+1 | |
2017-01-17 | userspace-header-gen: Don't generate first array size. | Christian Mauderer | 1 | -6/+10 | |
2017-01-10 | userspace-header-gen.py: Simplify program ports | Christian Mauderer | 1 | -0/+513 | |
