* | ftpd01: New test | Sebastian Huber | 2013-12-16 | 1 | -0/+117 | |
* | usb01: Remove SDHC references | Sebastian Huber | 2013-12-04 | 1 | -10/+0 | |
* | Fix default network init header | Sebastian Huber | 2013-12-04 | 1 | -2/+3 | |
* | ping01: New test | Sebastian Huber | 2013-11-13 | 2 | -0/+260 | |
* | Add network test support | Sebastian Huber | 2013-11-13 | 1 | -0/+51 | |
* | testsuite: Simplify tests | Sebastian Huber | 2013-11-13 | 10 | -58/+34 | |
* | timeout01: Avoid Nexus devices | Sebastian Huber | 2013-11-13 | 1 | -0/+5 | |
* | swi01: Avoid Nexus devices | Sebastian Huber | 2013-11-13 | 1 | -0/+5 | |
* | swi01: Fix warning | Sebastian Huber | 2013-11-13 | 1 | -0/+1 | |
* | usb01: Fix warning | Sebastian Huber | 2013-11-13 | 1 | -1/+0 | |
* | Update to FreeBSD 9.2 | Sebastian Huber | 2013-11-11 | 1 | -1/+1 | |
* | Rename rtems-bsd-config.h | Sebastian Huber | 2013-11-11 | 5 | -5/+5 | |
| | | | | Rename rtems-bsd-config.h in rtems-bsd-kernel-space.h. | |||||
* | syscalls01: Update due to RTEMS changes | Sebastian Huber | 2013-11-04 | 1 | -1/+1 | |
* | commands01: Add INET6 test cases | Sebastian Huber | 2013-10-31 | 1 | -0/+51 | |
* | Enable INET6 | Sebastian Huber | 2013-10-31 | 1 | -1/+1 | |
* | netshell01: Avoid multiple definitions | Sebastian Huber | 2013-10-31 | 1 | -5/+0 | |
* | selectpollkqueue01: New test | Sebastian Huber | 2013-10-31 | 1 | -0/+997 | |
* | TIMEOUT(9): Use timer server for callout_tick() | Sebastian Huber | 2013-10-31 | 3 | -166/+0 | |
* | Use kqueue() and kevent() from FreeBSD | Sebastian Huber | 2013-10-31 | 1 | -0/+151 | |
* | testsuite: Increase object alloc size | Sebastian Huber | 2013-10-31 | 1 | -0/+1 | |
* | Use poll() from FreeBSD | Sebastian Huber | 2013-10-31 | 1 | -0/+75 | |
* | testsuite: Increase test init task stack size | Sebastian Huber | 2013-10-31 | 1 | -1/+1 | |
* | rwlock01: New test | Sebastian Huber | 2013-10-31 | 1 | -0/+558 | |
* | Use select() from FreeBSD | Sebastian Huber | 2013-10-31 | 1 | -0/+75 | |
* | sleep01: New test | Sebastian Huber | 2013-10-31 | 1 | -0/+244 | |
* | loopback01: Wait for client termination | Sebastian Huber | 2013-10-31 | 1 | -7/+49 | |
* | loopback01: Initialize via IFCONFIG(8) | Sebastian Huber | 2013-10-31 | 1 | -23/+18 | |
* | commands01: New test | Sebastian Huber | 2013-10-31 | 1 | -0/+242 | |
* | Move TIMEOUT(9) and ZONE(9) initialization | Sebastian Huber | 2013-10-31 | 3 | -26/+0 | |
| | | | | Delete most of virtual memory support. | |||||
* | Move program control to thread structure | Sebastian Huber | 2013-10-31 | 1 | -0/+196 | |
* | Use send/recv functions from FreeBSD | Sebastian Huber | 2013-10-31 | 1 | -0/+207 | |
| | | | | Use recvfrom(), recvmsg(), sendto() and sendmsg() from FreeBSD. | |||||
* | Use socket read() and write() from FreeBSD | Sebastian Huber | 2013-10-31 | 1 | -0/+66 | |
* | Use getsockname() from FreeBSD | Sebastian Huber | 2013-10-31 | 1 | -0/+55 | |
* | Use getpeername() from FreeBSD | Sebastian Huber | 2013-10-31 | 1 | -0/+51 | |
* | Use getsockopt() and setsockopt() from FreeBSD | Sebastian Huber | 2013-10-31 | 1 | -0/+101 | |
* | Use accept() from FreeBSD | Sebastian Huber | 2013-10-31 | 1 | -0/+52 | |
* | Use listen() from FreeBSD | Sebastian Huber | 2013-10-31 | 1 | -0/+55 | |
* | Use connect() from FreeBSD | Sebastian Huber | 2013-10-31 | 1 | -0/+58 | |
* | Use socket ioctl() from FreeBSD | Sebastian Huber | 2013-10-31 | 1 | -0/+52 | |
* | Use bind() from FreeBSD | Sebastian Huber | 2013-10-31 | 1 | -0/+71 | |
* | Use shutdown() from FreeBSD | Sebastian Huber | 2013-10-31 | 1 | -3/+49 | |
* | Add socket fstat() support | Sebastian Huber | 2013-10-31 | 1 | -0/+104 | |
* | Import socket() implementation from FreeBSD | Sebastian Huber | 2013-10-31 | 1 | -0/+310 | |
| | | | | Add new test syscalls01. | |||||
* | testsuite: Enable stack checker | Sebastian Huber | 2013-10-31 | 1 | -0/+3 | |
| | | | | Increase init task stack size. | |||||
* | Use extension to attach a struct thread to threads | Sebastian Huber | 2013-10-10 | 5 | -1/+312 | |
| | | | | Add test thread01. | |||||
* | Make default test initialization task preemptive | Sebastian Huber | 2013-10-10 | 1 | -0/+2 | |
* | Move core system initialization references | Sebastian Huber | 2013-10-10 | 2 | -4/+0 | |
* | Update files to match FreeBSD layout | Sebastian Huber | 2013-10-10 | 24 | -320/+53 | |
| | | | | | | | | | | | | | | | | | | | Add compatibility with Newlib header files. Some FreeBSD header files are mapped by the translation script: o rtems/bsd/sys/_types.h o rtems/bsd/sys/errno.h o rtems/bsd/sys/lock.h o rtems/bsd/sys/param.h o rtems/bsd/sys/resource.h o rtems/bsd/sys/time.h o rtems/bsd/sys/timespec.h o rtems/bsd/sys/types.h o rtems/bsd/sys/unistd.h It is now possible to include <sys/socket.h> directly for example. Generate one Makefile which builds everything including tests. | |||||
* | Move files to match FreeBSD layout | Sebastian Huber | 2013-10-10 | 1 | -0/+0 | |
* | netshell01: Add netstat command | Joel Sherrill | 2012-10-23 | 1 | -0/+1 | |
