* | mcast01: Add test program | Sebastian Huber | 2020-09-10 | 1 | -0/+285 |
* | ifmcstat: Port to RTEMS | Sebastian Huber | 2020-09-10 | 1 | -0/+1 |
* | Fix linker errors with minimal build set | Sebastian Huber | 2020-08-06 | 1 | -0/+4 |
* | telnet: Use rtems_shell_dup_current_env() | Sebastian Huber | 2020-08-06 | 6 | -6/+6 |
| | | | | Update #3859. | ||||
* | testsuite: Use new name of test-info.h. | Christian Mauderer | 2020-07-31 | 12 | -13/+13 |
| | | | | | In RTEMS the test.h has been renamed to test-info.h to allow the new test framework to take over. | ||||
* | mDNSResponder: Port to RTEMS | Sebastian Huber | 2020-06-23 | 1 | -1/+1 |
| | | | | Update #4010. | ||||
* | epoch01: Fix sporadic test failures | Sebastian Huber | 2020-06-23 | 1 | -0/+4 |
* | testsuite: A description for each test added | Moyano, Gabriel | 2020-04-09 | 55 | -55/+413 |
* | testsuite: CONFIGURE_MAXIMUM_FILE_DESCRIPTORS | Sebastian Huber | 2020-04-03 | 10 | -10/+10 |
* | testsuite: User input define added | Moyano, Gabriel | 2020-03-31 | 19 | -5/+24 |
* | testsuite: Using RTEMS tester functions at beginning and at the end of tests | Moyano, Gabriel | 2020-03-31 | 11 | -17/+39 |
| | | | | puts() was replaced with rtems_test_begin() and rtems_test_end() | ||||
* | epoch01: Update due to API changes | Sebastian Huber | 2020-02-10 | 1 | -16/+16 |
| | | | | Update #3815. | ||||
* | syscalls01: Fix sporadic test failures | Sebastian Huber | 2020-02-10 | 1 | -0/+6 |
* | SOCKATMARK(3): Import from FreeBSD | Sebastian Huber | 2019-12-19 | 1 | -0/+30 |
| | | | | Update #3798. | ||||
* | Update to FreeBSD head 2019-09-24 | Sebastian Huber | 2019-11-13 | 3 | -7/+2 |
| | | | | Git mirror commit 6b0307a0a5184339393f555d5d424190d8a8277a. | ||||
* | test/syscalls01: Fix sporadic test failures | Sebastian Huber | 2019-11-13 | 1 | -0/+1 |
* | Fix warnings | Sebastian Huber | 2019-09-24 | 7 | -13/+18 |
* | Compatibility for next Newlib update | Sebastian Huber | 2019-09-24 | 1 | -0/+5 |
* | Add pselect() | Sebastian Huber | 2019-09-23 | 2 | -1/+137 |
* | test/syscalls01: Fix sporadic test failures | Sebastian Huber | 2019-09-23 | 1 | -0/+32 |
* | CONFIG_INTRHOOK(9): Call handlers after boot | Sebastian Huber | 2019-09-23 | 1 | -4/+30 |
| | | | | | This enables adding drivers on demand which use this service after initialization. | ||||
* | Add wrapper for strndup() | Sebastian Huber | 2019-09-11 | 1 | -6/+24 |
* | media01: Reduce record item count | Sebastian Huber | 2019-08-27 | 1 | -1/+1 |
* | media01: Enable event recording | Sebastian Huber | 2019-08-26 | 1 | -0/+8 |
* | Add mmap | Vijay Kumar Banerjee | 2019-07-27 | 3 | -2/+26 |
* | EPOCH(9): Add epoch_drain_callbacks() | Sebastian Huber | 2019-07-09 | 1 | -0/+50 |
* | test/epoch01: Simplify | Sebastian Huber | 2019-07-09 | 1 | -48/+36 |
* | test/commands01: Fix sporadic test failures | Sebastian Huber | 2019-06-26 | 1 | -1/+29 |
* | test/program01: Fix sporadic test failures | Sebastian Huber | 2019-06-26 | 1 | -0/+8 |
* | config: Control the interface from the command line net config file. | Chris Johns | 2019-06-12 | 1 | -1/+1 |
* | Fix zero-copy mbuf support | Sebastian Huber | 2019-05-13 | 1 | -3/+3 |
| | | | | In 2017 there was a change in the mbuf API. | ||||
* | Update due to API changes | Sebastian Huber | 2019-04-11 | 2 | -2/+2 |
* | openssl02: Fix includes | Sebastian Huber | 2019-03-29 | 1 | -7/+3 |
* | bin/openssl: Port to RTEMS. | Christian Mauderer | 2019-03-27 | 1 | -0/+135 |
* | rcconf02: Reduce maximum connection counts | Sebastian Huber | 2019-03-11 | 1 | -2/+2 |
| | | | | This avoids a file descriptor exhaustion. | ||||
* | openssl01: Call standard initialization functions | Sebastian Huber | 2018-10-25 | 1 | -0/+5 |
* | openssl01: New test | Sebastian Huber | 2018-10-25 | 1 | -0/+139 |
* | ppp01: Use novj option on host side | Sebastian Huber | 2018-10-17 | 1 | -2/+3 |
| | | | | | | | | The VJ compression seems to be not supported by libbsd. Without this option the following errors show up on the host side: rcvd [LCP ProtRej id=0x75 00 2f 45 00 00 34 6b 9a 40 00 40 01 85 87 c0 a8 64 0b c0 a8 64 46 89 3c 00 15 2c 27 95 c2 0a 88 ...] Protocol-Reject for unsupported protocol 'VJ uncompressed TCP/IP' (0x2f) | ||||
* | Fix dhcpcd.conf content | Sebastian Huber | 2018-10-11 | 1 | -4/+4 |
| | | | | | Do not write '\0' characters to the file. This confuses the options parser. | ||||
* | Increase file descriptors in default network cfg | Sebastian Huber | 2018-10-10 | 1 | -1/+1 |
| | | | | Make sure we can start the Telnet server in the default configuration. | ||||
* | media01: Improve output messages | Sebastian Huber | 2018-09-25 | 1 | -12/+7 |
| | | | | | Use a single printf() call to avoid interference from other output. Do not print the listener argument. | ||||
* | Update to FreeBSD head 2018-09-17 | Sebastian Huber | 2018-09-21 | 1 | -6/+11 |
| | | | | | | Git mirror commit 6c2192b1ef8c50788c751f878552526800b1e319. Update #3472. | ||||
* | Update to FreeBSD head 2018-06-01 | Sebastian Huber | 2018-09-21 | 3 | -0/+3017 |
| | | | | | | Git mirror commit fb63610a69b0eb7f69a201ba05c4c1a7a2739cf9. Update #3472. | ||||
* | syscalls01: Fix for IPSEC enabled | Sebastian Huber | 2018-08-28 | 1 | -0/+5 |
* | tests/termios: Fix warnings | Sebastian Huber | 2018-08-20 | 1 | -3/+11 |
* | testsuite/ipsec01: Add. | Christian Mauderer | 2018-08-02 | 4 | -0/+347 |
* | ipsec-tools: Port libipsec, setkey and racoon. | Christian Mauderer | 2018-08-02 | 1 | -0/+9 |
| | | | | | Note that this replaces the libipsec from FreeBSD with the one provided by ipsec-tools. | ||||
* | selectpollkqueue01: Invalidate file descriptor | Sebastian Huber | 2018-07-26 | 1 | -0/+6 |
| | | | | This is not a functional change or a fix. | ||||
* | Fix sporadic test failures via uma_timeout() | Sebastian Huber | 2018-07-26 | 2 | -13/+15 |
* | syscalls01: Fix sporadic test failures | Sebastian Huber | 2018-07-02 | 1 | -0/+14 |
