* | Add tests for USB keyboard and mouse as well as EVDEV | Kevin Kirspel | 2017-05-19 | 3 | -0/+1325 |
* | Adding USB Serial test | Kevin Kirspel | 2017-05-12 | 1 | -0/+329 |
* | Adding test cases for FREEBSD termios support through tty | Kevin Kirspel | 2017-05-11 | 12 | -0/+2977 |
* | rc_conf: Add support for ifconfig_<interface>_alias[0-9]+. | Chris Johns | 2017-04-27 | 2 | -2/+60 |
| | | | | | | | | | | The interface alias allows extra IP addresses to be set on and interface and it also allows the MAC address to be set. Examples: ifconfig_em0="inet 10.10.5.33 netmask 255.255.255.0" ifconfig_em0_alias0="ether 10:22:33:44:55:66" ifconfig_em0_alias1="inet 10.1.1.111 netmask 0xffffffff" | ||||
* | Enable bridging by default | Sebastian Huber | 2017-04-04 | 1 | -0/+1 |
* | media01: Add cpuinfo command | Sebastian Huber | 2017-03-08 | 1 | -0/+1 |
* | Add poll() and select() support for Termios | Sebastian Huber | 2017-02-28 | 1 | -2/+119 |
* | netshell01: Add license, fix format | Sebastian Huber | 2017-02-28 | 1 | -8/+32 |
* | Update due to configuration API changes | Sebastian Huber | 2017-02-21 | 2 | -6/+2 |
* | Port LPC32XX Ethernet and USB OHCI to RTEMS | Kevin Kirspel | 2017-02-14 | 1 | -0/+2 |
* | testsuite/commands01: Add wlanstats call. | Christian Mauderer | 2017-01-17 | 1 | -0/+17 |
* | freebsd/wlanstats: Port to FreeBSD. | Christian Mauderer | 2017-01-17 | 1 | -1/+2 |
* | Use thread name support | Sebastian Huber | 2017-01-13 | 4 | -4/+1 |
| | | | | Update #2858. | ||||
* | pf: Some fixes after the update | Sebastian Huber | 2017-01-10 | 1 | -1/+2 |
* | ARP(8): Port to RTEMS | Sebastian Huber | 2017-01-10 | 3 | -0/+3 |
* | VMSTAT(8): Port to RTEMS | Sebastian Huber | 2017-01-10 | 3 | -3/+6 |
* | Enable multi-cast routing support | Sebastian Huber | 2017-01-10 | 1 | -0/+2 |
* | Update to FreeBSD head 2016-08-23 | Sebastian Huber | 2017-01-10 | 1 | -0/+1 |
| | | | | Git mirror commit 9fe7c416e6abb28b1398fd3e5687099846800cfd. | ||||
* | PIPE(2): Port to RTEMS | Kevin Kirspel | 2016-12-23 | 1 | -2/+181 |
* | Add BRIDGE(4) support to configuration | Sebastian Huber | 2016-12-15 | 1 | -0/+1 |
* | Add a RTEMS Debugger TCP remote transport. | Chris Johns | 2016-11-29 | 1 | -0/+71 |
| | | | | | | | The patch also adds support to libbsd's build system making source conditional on a configure check. The debugger support is not available on all architectures and this feature lets us test if is avaliable. | ||||
* | Fix default network memory configuration | Sebastian Huber | 2016-11-10 | 2 | -4/+7 |
* | Modify rtems_bsd_set_vprintf_handler() | Sebastian Huber | 2016-11-09 | 1 | -1/+3 |
| | | | | Return previous vprintf()-handler in rtems_bsd_set_vprintf_handler(). | ||||
* | testsuite: Fix warnings | Sebastian Huber | 2016-10-07 | 5 | -5/+3 |
* | usb01: Simplify test program | Sebastian Huber | 2016-09-28 | 8 | -1072/+124 |
* | devfs: Create path. | Christian Mauderer | 2016-08-16 | 1 | -4/+11 |
* | pf: Add configuration via rc.conf. | Christian Mauderer | 2016-08-08 | 1 | -1/+42 |
* | testsuite/pf01: Remove pflog-module from test. | Christian Mauderer | 2016-08-08 | 1 | -1/+0 |
| | | | | | This module is not tested inside the pf01 test. Therefore remove it. It is still build in the interactive pf02 test. | ||||
* | pf: Add RTEMS_BSD_CONFIG_FIREWALL_xxx options. | Christian Mauderer | 2016-08-08 | 2 | -4/+4 |
* | testsuite/pf02: Add interactive pf test. | Christian Mauderer | 2016-08-03 | 1 | -0/+196 |
* | testsuite/pf01: Test pfctl and pf. | Christian Mauderer | 2016-08-02 | 1 | -0/+450 |
* | rtemsbsd: Add wrapper for open, fopen, malloc, ... | Christian Mauderer | 2016-08-02 | 1 | -0/+235 |
| | | | | | | | | | | | | | | | | | Add the following rtems_bsd_program_... wrapper: * rtems_bsd_program_open * rtems_bsd_program_socket * rtems_bsd_program_close * rtems_bsd_program_fopen * rtems_bsd_program_fclose * rtems_bsd_program_malloc * rtems_bsd_program_calloc * rtems_bsd_program_realloc * rtems_bsd_program_free * rtems_bsd_program_strdup * rtems_bsd_program_vasprintf * rtems_bsd_program_asprintf | ||||
* | rtemsbsd: Add call to program with a data restore | Christian Mauderer | 2016-08-02 | 1 | -0/+34 |
| | | | | This adds the rtems_bsd_program_call_main_width_data_restore function. | ||||
* | testsuite/syscalls01: Split out program01 part. | Christian Mauderer | 2016-08-02 | 2 | -194/+318 |
| | | | | | | This allows to use normal functions for sockets and similar while allowing to test the upcoming rtems_bsd_program_opan/close/... for the program part. | ||||
* | testsuite/pf01: Add test that links PF. | Christian Mauderer | 2016-08-01 | 1 | -0/+47 |
* | testsuite/cdev01: Add test for cdev functions. | Christian Mauderer | 2016-08-01 | 3 | -0/+352 |
* | Set syslog priority to 'debug' for all tests. | Chris Johns | 2016-07-06 | 2 | -0/+10 |
* | Add a wait for key press to test rccof02. | Chris Johns | 2016-07-01 | 1 | -11/+32 |
* | Add telnetd as service to rc.conf. | Chris Johns | 2016-07-01 | 1 | -15/+7 |
* | Add RTEMS_BSD_CONFIG_DOMAIN_PAGE_MBUFS_SIZE. | Chris Johns | 2016-06-30 | 3 | -17/+10 |
| | | | | | The domain allocator page abd mbuf size can be configured by the user using RTEMS_BSD_CONFIG_DOMAIN_PAGE_MBUFS_SIZE. | ||||
* | Add DHCP support to rc.conf. | Chris Johns | 2016-06-30 | 1 | -19/+56 |
* | Add ftpd as a service. Add rtems-bsd-config.h for app libbsd set up. | Chris Johns | 2016-06-28 | 2 | -20/+43 |
* | Add a services base test. | Chris Johns | 2016-06-27 | 1 | -0/+167 |
* | Refactor rc.conf processing to be services based. | Chris Johns | 2016-06-27 | 1 | -30/+128 |
* | Add DEFAULT_NETWORK_PAGE_MBUFS_SIZE to allow per BSP allocation domain sizes. | Chris Johns | 2016-06-27 | 3 | -0/+15 |
* | Update due to RTEMS printer API changes | Sebastian Huber | 2016-06-23 | 1 | -0/+1 |
* | Update due to RTEMS printer API changes | Sebastian Huber | 2016-06-23 | 2 | -0/+2 |
* | nfsclient: Port to LibBSD | Sebastian Huber | 2016-06-10 | 1 | -0/+69 |
* | ftpfs: Import from RTEMS | Sebastian Huber | 2016-06-10 | 1 | -0/+265 |
| | | | | RTEMS Git commit 251c94d3d3d27e0039f01b718e5c2eb06f39fdf7. | ||||
* | selectpollkqueue01: Add EVFILT_USER test case | Sebastian Huber | 2016-06-10 | 1 | -0/+49 |
