2017-10-23 | Import DPAA driver snapshot | Sebastian Huber | 1 | -0/+6 | |
Imported from Freescale Linux repository git://git.freescale.com/ppc/upstream/linux.git commit 2774c204cd8bfc56a200ff4dcdfc9cdf5b6fc161. Linux compatibility layer is partly from FreeBSD. | |||||
2017-10-20 | Add CPUINFO command to default network init | Sebastian Huber | 1 | -0/+1 | |
2017-10-20 | media01: Scale with processor count | Sebastian Huber | 1 | -2/+6 | |
2017-10-20 | tests: Remove obsolete config defines | Sebastian Huber | 4 | -12/+0 | |
2017-08-25 | Include missing <string.h> and <limits.h> | Sebastian Huber | 11 | -21/+29 | |
Fix warnings. Update #2132. Update #2133. | |||||
2017-06-08 | Use <sys/lock.h> provided by Newlib | Sebastian Huber | 6 | -14/+9 | |
2017-06-08 | Update due to Newlib 2017-06-07 changes | Sebastian Huber | 17 | -98/+19 | |
The following files are now provided by Newlib: * arpa/inet.h * net/if.h * netinet/in.h * netinet/tcp.h * sys/socket.h * sys/uio.h * sys/un.h The <sys/param.h> and <sys/cpuset.h> are now compatible enough to be used directly. Update #2833. | |||||
2017-05-19 | Add tests for USB keyboard and mouse as well as EVDEV | Kevin Kirspel | 3 | -0/+1325 | |
2017-05-12 | Adding USB Serial test | Kevin Kirspel | 1 | -0/+329 | |
2017-05-11 | Adding test cases for FREEBSD termios support through tty | Kevin Kirspel | 12 | -0/+2977 | |
2017-04-27 | rc_conf: Add support for ifconfig_<interface>_alias[0-9]+. | Chris Johns | 2 | -2/+60 | |
The interface alias allows extra IP addresses to be set on and interface and it also allows the MAC address to be set. Examples: ifconfig_em0="inet 10.10.5.33 netmask 255.255.255.0" ifconfig_em0_alias0="ether 10:22:33:44:55:66" ifconfig_em0_alias1="inet 10.1.1.111 netmask 0xffffffff" | |||||
2017-04-04 | Enable bridging by default | Sebastian Huber | 1 | -0/+1 | |
2017-03-08 | media01: Add cpuinfo command | Sebastian Huber | 1 | -0/+1 | |
2017-02-28 | Add poll() and select() support for Termios | Sebastian Huber | 1 | -2/+119 | |
2017-02-28 | netshell01: Add license, fix format | Sebastian Huber | 1 | -8/+32 | |
2017-02-21 | Update due to configuration API changes | Sebastian Huber | 2 | -6/+2 | |
2017-02-14 | Port LPC32XX Ethernet and USB OHCI to RTEMS | Kevin Kirspel | 1 | -0/+2 | |
2017-01-17 | testsuite/commands01: Add wlanstats call. | Christian Mauderer | 1 | -0/+17 | |
2017-01-17 | freebsd/wlanstats: Port to FreeBSD. | Christian Mauderer | 1 | -1/+2 | |
2017-01-13 | Use thread name support | Sebastian Huber | 4 | -4/+1 | |
Update #2858. | |||||
2017-01-10 | pf: Some fixes after the update | Sebastian Huber | 1 | -1/+2 | |
2017-01-10 | ARP(8): Port to RTEMS | Sebastian Huber | 3 | -0/+3 | |
2017-01-10 | VMSTAT(8): Port to RTEMS | Sebastian Huber | 3 | -3/+6 | |
2017-01-10 | Enable multi-cast routing support | Sebastian Huber | 1 | -0/+2 | |
2017-01-10 | Update to FreeBSD head 2016-08-23 | Sebastian Huber | 1 | -0/+1 | |
Git mirror commit 9fe7c416e6abb28b1398fd3e5687099846800cfd. | |||||
2016-12-23 | PIPE(2): Port to RTEMS | Kevin Kirspel | 1 | -2/+181 | |
2016-12-15 | Add BRIDGE(4) support to configuration | Sebastian Huber | 1 | -0/+1 | |
2016-11-29 | Add a RTEMS Debugger TCP remote transport. | Chris Johns | 1 | -0/+71 | |
The patch also adds support to libbsd's build system making source conditional on a configure check. The debugger support is not available on all architectures and this feature lets us test if is avaliable. | |||||
2016-11-10 | Fix default network memory configuration | Sebastian Huber | 2 | -4/+7 | |
2016-11-09 | Modify rtems_bsd_set_vprintf_handler() | Sebastian Huber | 1 | -1/+3 | |
Return previous vprintf()-handler in rtems_bsd_set_vprintf_handler(). | |||||
2016-10-07 | testsuite: Fix warnings | Sebastian Huber | 5 | -5/+3 | |
2016-09-28 | usb01: Simplify test program | Sebastian Huber | 8 | -1072/+124 | |
2016-08-16 | devfs: Create path. | Christian Mauderer | 1 | -4/+11 | |
2016-08-08 | pf: Add configuration via rc.conf. | Christian Mauderer | 1 | -1/+42 | |
2016-08-08 | testsuite/pf01: Remove pflog-module from test. | Christian Mauderer | 1 | -1/+0 | |
This module is not tested inside the pf01 test. Therefore remove it. It is still build in the interactive pf02 test. | |||||
2016-08-08 | pf: Add RTEMS_BSD_CONFIG_FIREWALL_xxx options. | Christian Mauderer | 2 | -4/+4 | |
2016-08-03 | testsuite/pf02: Add interactive pf test. | Christian Mauderer | 1 | -0/+196 | |
2016-08-02 | testsuite/pf01: Test pfctl and pf. | Christian Mauderer | 1 | -0/+450 | |
2016-08-02 | rtemsbsd: Add wrapper for open, fopen, malloc, ... | Christian Mauderer | 1 | -0/+235 | |
Add the following rtems_bsd_program_... wrapper: * rtems_bsd_program_open * rtems_bsd_program_socket * rtems_bsd_program_close * rtems_bsd_program_fopen * rtems_bsd_program_fclose * rtems_bsd_program_malloc * rtems_bsd_program_calloc * rtems_bsd_program_realloc * rtems_bsd_program_free * rtems_bsd_program_strdup * rtems_bsd_program_vasprintf * rtems_bsd_program_asprintf | |||||
2016-08-02 | rtemsbsd: Add call to program with a data restore | Christian Mauderer | 1 | -0/+34 | |
This adds the rtems_bsd_program_call_main_width_data_restore function. | |||||
2016-08-02 | testsuite/syscalls01: Split out program01 part. | Christian Mauderer | 2 | -194/+318 | |
This allows to use normal functions for sockets and similar while allowing to test the upcoming rtems_bsd_program_opan/close/... for the program part. | |||||
2016-08-01 | testsuite/pf01: Add test that links PF. | Christian Mauderer | 1 | -0/+47 | |
2016-08-01 | testsuite/cdev01: Add test for cdev functions. | Christian Mauderer | 3 | -0/+352 | |
2016-07-06 | Set syslog priority to 'debug' for all tests. | Chris Johns | 2 | -0/+10 | |
2016-07-01 | Add a wait for key press to test rccof02. | Chris Johns | 1 | -11/+32 | |
2016-07-01 | Add telnetd as service to rc.conf. | Chris Johns | 1 | -15/+7 | |
2016-06-30 | Add RTEMS_BSD_CONFIG_DOMAIN_PAGE_MBUFS_SIZE. | Chris Johns | 3 | -17/+10 | |
The domain allocator page abd mbuf size can be configured by the user using RTEMS_BSD_CONFIG_DOMAIN_PAGE_MBUFS_SIZE. | |||||
2016-06-30 | Add DHCP support to rc.conf. | Chris Johns | 1 | -19/+56 | |
2016-06-28 | Add ftpd as a service. Add rtems-bsd-config.h for app libbsd set up. | Chris Johns | 2 | -20/+43 | |
2016-06-27 | Add a services base test. | Chris Johns | 1 | -0/+167 | |
